Hi Giulio,
Thanks for the reply.
Attached two screenshots with the analog in "reference levels" from two FSRs connected to the Bela as depicted here. Screenshots are from the IDE oscilloscope. As you can see from the PC time, the "reference levels" (meaning no force applied to the FSR) changed within the span of 10min.
I will order a 3.3V adapter but delivery time is several weeks (Canadian winter season;-)). I read here that "Powering Bela Mini from a battery with less than 4.5V will cause the analog inputs to stop working". I do not have a Bela Mini but doesn't the Beaglebone and normal Bela require 5V?
Thanks for any input!
