Hello everyone!
I'm struggling a bit with this problem, so maybe hopefully someone who has tried this before could help me out.
I am trying to build a patch whereby audio reacts to the input of a weight sensor (connected via HX711). The thing is I cannot seem to get the input to print (I connected the ground and 3.3V correctly, and used the digital 0 and digital 1 input for the clock and data signal), leading me to believe I made a mistake somehwere, or that maybe there is no compatibility (with Arduino it works).
Has anyone tried this before and wants to share their wisdom?
You're in luck, look here:
https://forum.bela.io/d/5538-hx710b-air-pressure-0-40kpa-sensor-module/73
This is for a pressure sensor which uses a similar ADC. I have the HX711 and a load cell and tried it, and it works very well to get the raw values from the sensor. You need the included custom render file and a receiver in a Pd patch. Then you simply rescale in Pd for whatever you want. This was a project I started during the holidays and with the precious help from giuiliomoro who made the custom render. On the Pd side, all you need is a receiver [r hx710].
