Hi all,
I've just built a pepper from the kit bought directly from Bela.io. I can use the IDE to upload to the "Getting Started" pure data example to the Bela board fine, and the digital outs (LEDs) and ins (Buttons) are working correctly. I don't get any test tone from the audio outputs, or passthrough from the audio inputs, or and pass through from the analog I/O. I also can't see anything on the IDE scope.
If I remove the bela board, run the same project and connect headphones I can hear the test tone, so it seems like it must be something to do with my Pepper build 🙁
I have looked at the schematic and can't see anything obviously wrong with my build. Using a meter I can see that the IC is connected correctly to the IO and the Bela board. I can also see that the analog IO appears to be connected to the analog IO pins, and the supply voltages all seem to be correct.
This make me think I'm missing something obvious or doing something stupid, does anyone have any idea what I could be doing wrong here?
