I've been designing a Trill-based peripheral for a project and thought I'd try and use some of the Picos I have lying around my desk.
If I could crack this I could finally use them up and they look like really capable boards with plenty of IO and power.
I've managed to get it to build and recognise the Square I have to hand but I have no idea why I can't seem to get the size or location of the touch, just the number.
I've already had a little bit of a play with and had ported most of the Trill-Linux library to openFrameworks and Raspberry Pi with some success so I thought I'd try my hand at trying to do the same for the Pico because I have a pile of them.
Does anyone want to have a look and maybe pitch in? @Grumpy_Mike I saw the work you did in porting the library to MicroPython, are you up to having a crack? @giuliomoro I know you're a developer of some skill.
https://github.com/PeteHaughie/Trill-Pico
FWIW I've also tried the Pico in Arduino mode and can't seem to get that to work with the Trill library at all, but then again I also couldn't get that to work with a Seeeduino Xiao either… I could however get it working fine with an Arduino Micro as a last hail mary to unblock me.
