Hello everybody,
I've built my self a nice amp/speaker emulation using the Bela and the RTNeural framework. It is now embeded into my pedalboard and has survived two intense days of recording in studio.
My last problem at this point is that I'm not able to automatically launch the project on the bela boot sequence. The IDE option does not work because I use some make option essential to build RTNeural. I've also tried the shell script but it ends up being unusable because of many xruns I don't encounter when the project is launch from the IDE.
Is there some documentation I could refer too ? I've try to do a decent research without finding a solution at this point.
Thank you for your time !
Jean-Loup
it should work if the project has already been built. Can you share your make parameters?
Hello !
I can confirm that it was as simple as removing the semicolon at the end of the make parameters. Everything is working fine, thank you !
