MarinosK Hi all, I am using a usb class compliant microphone to record ultrasounds - it is automatically recognised by my laptop as a 384K/16b audio interface having only 1 input (no output). I was wandering if there is a way to use it with Bela so that I use it as an audio input while monitoring audio with Bela - is that possible? would that affect Bela's latency somehow? thx.
giuliomoro That is not doable, unfortunately. In order to work in low-latency mode, Bela has to use its own hardware (because that connects directly to the multi-channel audio serial port of the system on chip, as opposed to using a USB connection).
