giuliomoro Another temporary workaround is to remove the _float suffix, or replace it with _c and that will run the C implementation instead ofhe NEoN one. It will be a bit slower
stephanelesoinne giuliomoro Unfortunately not an option for me as I'm already close to the processing power limit even with neon. But I have a second board with a non updated image that I will use until the problem is fixed.
giuliomoro ok, I think I fixed it for real now I hope. Here it is : https://github.com/BelaPlatform/Bela/raw/dev/resources/stretch/deb/libne10-dev_20181116-1_armhf.deb
stephanelesoinne giuliomoro Thank you Giulio. With the update https://github.com/BelaPlatform/Bela/tree/dev-websocket-rebased and the new ne10 package, the problems have been solved.
giuliomoro great, sorry it took a while. We will merge that branch in later on, at which point all the functionalities will be on the master branch.
