Marije updated the examples and these can be found on the master of the Bela repo, as well as on the new image.
Incidentally, I also played around with checkinstall to make .deb packages for easier installation and upgrade, so SuperCollider is now available as a deb package here.
So if you do not want to upgrade your image, you can upload that file on the board and run
dpkg --install supercollider-3.8dev-Bela-build_20161024-1_armhf.deb
NOTE: if you have an image older than 0.1.1, then you will have to manually clean your board from an old stale version in there:
rm -r /usr/local/lib/SuperCollider/;
rm -r /usr/local/share/SuperCollider/;
rm /usr/local/bin/sclang;
rm /usr/local/bin/sclangpipe_app ;
rm /usr/local/bin/scsynth;
rm /usr/local/bin/scvim;
