Working on a project that needs to read data from an Adafruit MPR121, using Pd. I swear I got this working before but I cannot figure out what is wrong with my custom render file. I keep getting a segmentation fault error. I am just trying to pass the sensor values to Pd to then print to console & confirm that they're getting into Pd. This part of the code is not the issue because when I comment it out and use a different _main.pd file I get the same error. There's something wrong with the MPR121 code or how I'm handling it. (I am not super knowledgeable about coding). Can someone please help?! The demo MPR121 code works fine.
* Default render file for Bela projects running Pd patches
* using libpd.
MODIFIED -- MPR121
additions will be noted
//MODIFIED
#include <cmath>
#include "I2C_MPR121.h"
#define NUM_TOUCH_PINS 12
// Define this to print data to terminal
#undef DEBUG_MPR121
// Enable features here. These may be undef'ed below if the corresponding
// BELA_LIBPD_DISABLE_* flag is passed
#define BELA_LIBPD_SCOPE
#define BELA_LIBPD_MIDI
#define BELA_LIBPD_TRILL
#define BELA_LIBPD_GUI
#define BELA_LIBPD_SERIAL
#ifdef BELA_LIBPD_DISABLE_SCOPE
#undef BELA_LIBPD_SCOPE
#endif // BELA_LIBPD_DISABLE_SCOPE
#ifdef BELA_LIBPD_DISABLE_MIDI
#undef BELA_LIBPD_MIDI
#endif // BELA_LIBPD_DISABLE_MIDI
#ifdef BELA_LIBPD_DISABLE_TRILL
#undef BELA_LIBPD_TRILL
#endif // BELA_LIBPD_DISABLE_TRILL
#ifdef BELA_LIBPD_DISABLE_GUI
#undef BELA_LIBPD_GUI
#endif // BELA_LIBPD_DISABLE_GUI
#ifdef BELA_LIBPD_DISABLE_SERIAL
#undef BELA_LIBPD_SERIAL
#endif // BELA_LIBPD_DISABLE_SERIAL
#define PD_THREADED_IO
#include <libraries/libpd/libpd.h>
#include <stdio.h>
//MODIFIED
// Change this to change how often the MPR121 is read (in Hz)
int readInterval = 40;
// Change this threshold to set the minimum amount of touch
int threshold = 40;
// This array holds the continuous sensor values
int sensorValue[NUM_TOUCH_PINS];
I2C_MPR121 mpr121; // Object to handle MPR121 sensing
AuxiliaryTask i2cTask; // Auxiliary task to read I2C
int readCount = 0; // How long until we read again...
int readIntervalSamples = 0; // How many samples between reads
void readMPR121(void*);
#ifdef BELA_LIBPD_MIDI
#endif // BELA_LIBPD_MIDI
#ifdef BELA_LIBPD_SCOPE
#endif // BELA_LIBPD_SCOPE
#include <string>
#include <sstream>
#include <string.h>
#include <vector>
#if (defined(BELA_LIBPD_GUI) || defined(BELA_LIBPD_TRILL))
template <typename T>
int getIdxFromId(const char* id, std::vector<std::pair<std::string,T>>& db)
for(unsigned int n = 0; n < db.size(); ++n)
if(0 == strcmp(id, db[n].first.c_str()))
return n;
return -1;
#endif // BELA_LIBPD_GUI || BELA_LIBPD_TRILL
#ifdef BELA_LIBPD_TRILL
#include <tuple>
AuxiliaryTask gTrillTask;
Pipe gTrillPipe;
static std::vector<std::string> gTrillAcks;
static std::vector<std::pair<std::string,Trill*>> gTouchSensors;
// how often to read the cap sensors inputs.
float touchSensorSleepInterval = 0.007;
void readTouchSensors(void*)
for(unsigned int n = 0; n < gTouchSensors.size(); ++n)
Trill& touchSensor = *gTouchSensors[n].second;
int ret;
const Trill::Device type = touchSensor.deviceType();
if(Trill::NONE == type)
ret = 1;
else
ret = touchSensor.readI2C();
if(!ret)
gTrillPipe.writeNonRt(n);
#endif // BELA_LIBPD_TRILL
#ifdef BELA_LIBPD_GUI
Pipe gGuiPipe;
Gui gui;
struct bufferDescription
std::string name;
int id;
int size;
static std::vector<struct bufferDescription> gGuiDataBuffers;
static std::vector<std::string> gGuiControlBuffers;
struct guiControlMessageHeader
uint32_t size;
uint32_t type;
uint32_t id;
bool guiControlDataCallback(JSONObject& root, void* arg)
int ret = true;
for(unsigned int n = 0; n < gGuiControlBuffers.size(); ++n)
const auto& b = gGuiControlBuffers[n];
std::wstring key = JSON::s2ws(b);
if (root.end() != root.find(key))
JSONValue* found = root[key];
struct guiControlMessageHeader header;
header.id = n;
char* array;
if(found->IsString())
std::string value = JSON::ws2s(found->AsString());
header.type = 's';
header.size = value.size();
array = (char*)alloca(header.size);
memcpy(array, value.c_str(), header.size);
} else if(found->IsNumber())
float value = found->AsNumber();
header.type = 'f';
header.size = sizeof(value);
memcpy(array, &value, header.size);
} else {
continue;
// do two separate reads: the pipe is datagram-based
// so it would be impossible to receive partial messages
// at the other end
gGuiPipe.writeNonRt(header);
gGuiPipe.writeNonRt(&array[0], header.size);
// we have successully parsed this message, so the
// default parser shouldn't when we return
// note: in practice there may be times when we'd want
// to have the default parser handle this message
// (e.g.: when an "event" field is also present), but
// for now we ignore them
ret = false;
continue;
return ret;
#ifdef BELA_LIBPD_SERIAL
#include <libraries/Serial/Serial.h>
#include <string>
Pipe gSerialPipe;
Serial gSerial;
std::string gSerialId;
int gSerialEom;
enum SerialType {
kSerialFloats,
kSerialSymbol,
kSerialSymbols,
} gSerialType = kSerialFloats;
AuxiliaryTask gSerialInputTask;
AuxiliaryTask gSerialOutputTask;
struct serialMessageHeader
uint32_t idSize;
uint32_t dataSize;
void serialOutputLoop(void* arg) {
// TODO: implement
void serialInputLoop(void* arg) {
char serialBuffer[10000];
unsigned int i = 0;
serialMessageHeader h = {
.idSize = strlen(gSerialId.c_str()) + 1,
while(!Bela_stopRequested())
// read from the serial port with a timeout of 100ms
int ret = gSerial.read(serialBuffer + i, sizeof(serialBuffer) - i, 100);
if (ret > 0) {
if(gSerialEom < 0)
h.dataSize = ret;
// send everything immediately
gSerialPipe.writeNonRt(h);
gSerialPipe.writeNonRt(gSerialId.c_str(), h.idSize);
gSerialPipe.writeNonRt(serialBuffer, h.dataSize);
} else {
// find EOM in new data
unsigned int searchStart = i;
unsigned int searchStop = searchStart + ret;
unsigned int n;
unsigned int lastSent = 0;
bool found;
do
found = false;
for(n = searchStart; n < searchStop; ++n)
if(serialBuffer[n] == gSerialEom)
found = true;
break;
// if found, send all data till that point
if(found)
h.dataSize = n - lastSent;
if(h.dataSize)
gSerialPipe.writeNonRt(serialBuffer + lastSent, h.dataSize);
searchStart = n + 1;
lastSent += 1 + h.dataSize;
while(found);
// if we are left with any data, move it to the beginning of the buffer.
// TODO: avoid this and use it as a circular buffer
if(searchStart != i)
memmove(serialBuffer, serialBuffer + searchStart, searchStop - searchStart);
i = searchStop - searchStart;
#endif // BELA_LIBPD_SERIAL
static unsigned int gScopeChannelsInUse = 4;
#else // BELA_LIBPD_SCOPE
static unsigned int gScopeChannelsInUse = 0;
static unsigned int gFirstAnalogInChannel;
static unsigned int gFirstAnalogOutChannel;
settings->interleave = 0;
float* gInBuf;
float* gOutBuf;
#define PARSE_MIDI
int gMidiVerbose = 1;
const int kMidiVerbosePrintLevel = 1;
void dumpMidi()
if(midi.size() == 0)
return;
"Num",
"Name",
"In",
"Out",
"Pd channels"
n,
gMidiPortNames[n].c_str(),
n * 16 + 1,
n * 16 + 16
Midi* newMidi;
newMidi = new Midi();
#ifdef PARSE_MIDI
newMidi->enableParser(true);
#else
newMidi->enableParser(false);
#endif /* PARSE_MIDI */
if(verboseSuccess)
if(newMidi->isInputEnabled())
if(verboseSuccess)
if(verboseError)
fprintf(stderr, "Failed to open MIDI device %s\n", name.c_str());
return nullptr;
} else {
return newMidi;
unsigned int port = 0;
while(*channel >= 16){
*channel -= 16;
port += 1;
return port;
unsigned int port = getPortChannel(&channel);
if(gMidiVerbose >= kMidiVerbosePrintLevel)
port < midi.size() && midi[port]->writeNoteOn(channel, pitch, velocity);
port < midi.size() && midi[port]->writeControlChange(channel, controller, value);
port < midi.size() && midi[port]->writeProgramChange(channel, program);
value += 8192; // correct for Pd's oddity
port < midi.size() && midi[port]->writePitchBend(channel, value);
port < midi.size() && midi[port]->writeChannelPressure(channel, pressure);
port < midi.size() && midi[port]->writePolyphonicKeyPressure(channel, pitch, pressure);
if(port > (int)midi.size()){
port = 0;
port < (int)midi.size() && midi[port]->writeOutput(byte);
rt_printf("%s", received);
libpd_float((const char*)receiverName, (float)state);
// rt_printf("%s: %d\n", (char*)receiverName, state);
void setTrillPrintError()
rt_fprintf(stderr, "bela_setTrill format is wrong. Should be:\n"
"[mode <sensor_id> <prescaler_value>(\n"
" or\n"
"[threshold <sensor_id> <threshold_value>(\n"
" or\n"
"[prescaler <sensor_id> <prescaler_value>(\n");
void Bela_listHook(const char *source, int argc, t_atom *argv)
if(0 == strcmp(source, "bela_guiOut"))
if(!libpd_is_float(&argv[0]))
rt_fprintf(stderr, "Wrong format for bela_gui, the first element should be a float\n");
return;
unsigned int bufNum = libpd_get_float(&argv[0]);
if(libpd_is_float(&argv[1])) // if the first element is a float, we send an array of floats
float buf[argc - 1];
for(int n = 1; n < argc; ++n)
t_atom *a = &argv[n];
if(!libpd_is_float(a))
rt_fprintf(stderr, "Wrong format for bela_gui\n"); // this should never happen, because then the selector would've not been "float"
return;
buf[n - 1] = libpd_get_float(a);
gui.sendBuffer(bufNum, buf, argc - 1);
return;
} else { // otherwise we send each element of the list separately
if (libpd_is_float(a)) {
float x = libpd_get_float(a);
gui.sendBuffer(bufNum, x);
} else if (libpd_is_symbol(a)) {
const char *s = libpd_get_symbol(a);
gui.sendBuffer(bufNum, s, strlen(s)); // TODO: should it be strlen(s)+1?
return;
if(1 != argc || !libpd_is_float(argv))
rt_fprintf(stderr, "Wrong format for bela_setMidi, expected: [verbose <n>(\n");
} else {
gMidiVerbose = libpd_get_float(argv);
rt_printf("MIDI verbose: %d\n", gMidiVerbose);
return;
int num[3] = {0, 0, 0};
if(!libpd_is_float(&argv[n]))
fprintf(stderr, "Wrong format for bela_setMidi, expected:[hw 1 0 0(");
return;
if(newMidi)
midi.push_back(newMidi);
dumpMidi();
return;
bool disable = false;
direction = INPUT;
direction = OUTPUT;
disable = true;
} else {
return;
if(argc == 0){
return;
return;
int channel = libpd_get_float(&argv[0]) - gLibpdDigitalChannelOffset;
if(disable == true){
dcm.unmanage(channel);
return;
if(argc >= 2){
t_atom* a = &argv[1];
if(libpd_is_symbol(a)){
if(strcmp(s, "~") == 0 || strncmp(s, "sig", 3) == 0){
isMessageRate = false;
return;
if(strcmp(source, "bela_control") == 0){
if(strcmp("stop", symbol) == 0){
rt_printf("bela_control: stop\n");
Bela_requestStop();
return;
if(0 == strcmp(source, "bela_setGui"))
if(0 == strcmp(symbol, "new"))
if(
argc < 2
|| !libpd_is_symbol(argv)
|| !libpd_is_symbol(argv + 1)
return;
const char* mode = libpd_get_symbol(argv);
const char* name = libpd_get_symbol(argv + 1);
if(0 == strcmp(mode, "control"))
gGuiControlBuffers.emplace_back(name);
return;
if(0 == strcmp(mode, "array"))
// because of
// https://github.com/libpd/libpd/issues/274
// (again), we cannot access the arrays right
// here (as it would deadlock on loadbang), so
// we have to defer creation of the Gui
// buffers until render() runs
gGuiDataBuffers.emplace_back(bufferDescription{.name = name, .id = -1, .size = 0});
return;
return;
if(0 == strcmp(source, "bela_setSerial"))
if(
argc < 5
|| !libpd_is_symbol(argv + 0)
|| !libpd_is_float(argv + 2)
|| !libpd_is_symbol(argv + 3)
|| !libpd_is_symbol(argv + 4)
fprintf(stderr, "Invalid bela_setSerial arguments. Should be: `new serial_id device baudrate EOM type`, where `EOM` is one of `newline` or `none` and `type` is one of `floats`, `symbol`, `symbols`\n");
return;
gSerialId = libpd_get_symbol(argv + 0);
const char* device = libpd_get_symbol(argv + 1);
unsigned int baudrate = libpd_get_float(argv + 2);
const char* eom = libpd_get_symbol(argv + 3);
if(0 == strcmp(eom, "newline"))
gSerialEom = '\n';
else
gSerialEom = -1;
const char* type = libpd_get_symbol(argv + 4);
if(0 == strcmp("floats", type))
else if(0 == strcmp("symbol", type))
gSerialType = kSerialSymbol;
else if(0 == strcmp("symbols", type))
gSerialType = kSerialSymbols;
if(gSerial.setup(device, baudrate))
return;
gSerialInputTask = Bela_runAuxiliaryTask(serialInputLoop, 0);
gSerialOutputTask = Bela_runAuxiliaryTask(serialOutputLoop, 0);
if(0 == strcmp(source, "bela_setTrill"))
bool err = false;
uint8_t address = 0xff;
if(argc < 3)
err = true;
else if (!libpd_is_symbol(argv) // sensor_id
|| !libpd_is_float(argv + 1) // bus
|| !libpd_is_symbol(argv + 2) // device
err = true;
if(argc >= 4)
if(libpd_is_float(argv + 3))
address = libpd_get_float(argv + 3);
else
err = true;
if(err)
rt_fprintf(stderr, "bela_setTrill wrong format. Should be:\n"
"[new <sensor_id> <bus> <device> <address>(\n");
return;
const char* name = libpd_get_symbol(argv);
unsigned int bus = libpd_get_float(argv + 1);
const char* deviceString = libpd_get_symbol(argv + 2);
Trill::Device device = Trill::getDeviceFromName(deviceString);
Trill* trill = new Trill(bus, device, address);
if(Trill::NONE == trill->deviceType())
rt_fprintf(stderr, "Unable to create Trill %s device `%s` on bus %u at ", deviceString, name, bus);
if(128 < address)
rt_fprintf(stderr, "default address. ");
else
rt_fprintf(stderr, "address: %#x (%d). ", address, address);
rt_fprintf(stderr, "Is the device connected?\n");
return;
gTouchSensors.emplace_back(std::string(name), trill);
gTrillAcks.push_back(name);
//an ack is sent to Pd during the next audio callback because of https://github.com/libpd/libpd/issues/274
return;
if(argc < 1 || !libpd_is_symbol(argv))
rt_fprintf(stderr, "bela_setTrill: wrong format. It should be\n"
"[<command> <sensor_id> ...(");
return;
const char* sensorId = libpd_get_symbol(argv);
int idx = getIdxFromId(sensorId, gTouchSensors);
if(idx < 0)
rt_fprintf(stderr, "bela_setTrill sensor_id unknown: %s\n", sensorId);
return;
if(0 == strcmp(symbol, "updateBaseline"))
gTouchSensors[idx].second->updateBaseline();
return;
if(0 == strcmp(symbol, "mode"))
if(argc < 2
setTrillPrintError();
return;
const char* modeString = libpd_get_symbol(argv + 1);
Trill::Mode mode = Trill::getModeFromName(modeString);
gTouchSensors[idx].second->setMode(mode);
if(
0 == strcmp(symbol, "threshold")
|| 0 == strcmp(symbol, "prescaler")
if(
argc < 2
return;
float value = libpd_get_float(argv + 1);
if(0 == strcmp(symbol, "threshold"))
gTouchSensors[idx].second->setNoiseThreshold(value);
if(0 == strcmp(symbol, "prescaler"))
if(Trill::prescalerMax < value || 0 > value)
if(0 == value)
value = 0;
if(Trill::prescalerMax < value)
value = Trill::prescalerMax;
rt_printf("bela_setTrill prescaler value out of range, clipping to %u\n", value);
gTouchSensors[idx].second->setPrescaler(value);
return;
return;
// the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between gLibpdDigitalChannelOffset and (gLibpdDigitalCHannelOffset+gDigitalChannelsInUse)
static int prefixLength = strlen("bela_digitalOut");
unsigned int channel = receiver - gLibpdDigitalChannelOffset; // go back to the actual Bela digital channel number
if(channel < gDigitalChannelsInUse){ //number of digital channels
dcm.setValue(channel, value);
return;
std::vector<std::string> gReceiverInputNames;
std::vector<std::string> gReceiverOutputNames;
void generateDigitalNames(unsigned int numDigitals, unsigned int libpdOffset, std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
std::string outBaseString = "bela_digitalOut";
receiverInputNames.push_back(inBaseString + std::to_string(i+libpdOffset));
receiverOutputNames.push_back(outBaseString + std::to_string(i+libpdOffset));
void printDigitalNames(std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
printf("DIGITAL INPUTS\n");
for(unsigned int i=0; i<gDigitalChannelsInUse; i++)
printf("%s\n", receiverInputNames[i].c_str());
printf("DIGITAL OUTPUTS\n");
printf("%s\n", receiverOutputNames[i].c_str());
#ifdef PD_THREADED_IO
void fdLoop(void* arg){
while(!Bela_stopRequested()){
if(!sys_doio(pd_this))
usleep(3000);
#endif /* PD_THREADED_IO */
Scope scope;
float* gScopeOut;
void* gPatch;
bool gDigitalEnabled = 0;
gui.setup(context->projectName);
gui.setControlDataCallback(guiControlDataCallback, nullptr);
gGuiPipe.setup("guiControlPipe", 16384);
gSerialPipe.setup("serialPipe", 16384);
// Check Pd's version
int major, minor, bugfix;
return false;
return false;
gDigitalEnabled = 1;
char file[] = "_main.pd";
char folder[] = "./";
return false;
free(str);
// analog setup
printf("Audio channels in use: %d\n", context->audioOutChannels);
printf("Analog channels in use: %d\n", gAnalogChannelsInUse);
printf("Digital channels in use: %d\n", gDigitalChannelsInUse);
// Channel distribution
gFirstAnalogInChannel = std::max(context->audioInChannels, context->audioOutChannels);
gFirstAnalogOutChannel = gFirstAnalogInChannel;
gFirstDigitalChannel = gFirstAnalogInChannel + std::max(context->analogInChannels, context->analogOutChannels);
gLibpdDigitalChannelOffset = gFirstDigitalChannel + 1;
// Create receiverNames for digital channels
generateDigitalNames(gDigitalChannelsInUse, gLibpdDigitalChannelOffset, gReceiverInputNames, gReceiverOutputNames);
// digital setup
if(gDigitalEnabled)
if(gDigitalChannelsInUse > 0){
dcm.setCallbackArgument(ch, (void*) gReceiverInputNames[ch].c_str());
unsigned int n = 0;
if(newMidi)
++n;
} else {
dumpMidi();
return false;
libpd_set_listhook(Bela_listHook);
libpd_init();
gInBuf = get_sys_soundin();
gOutBuf = get_sys_soundout();
// start DSP:
// [; pd dsp 1(
libpd_start_message(1);
libpd_add_float(1.0f);
// Bind your receivers here
for(unsigned int i = 0; i < gDigitalChannelsInUse; i++)
libpd_bind(gReceiverOutputNames[i].c_str());
libpd_bind("bela_control");
libpd_bind("bela_setMidi");
libpd_bind("bela_guiOut");
libpd_bind("bela_setGui");
libpd_bind("bela_serialOut");
libpd_bind("bela_setSerial");
libpd_bind("bela_setTrill");
// open patch:
if(gPatch == NULL){
return false;
pdMultiplexerActive = true;
sys_dontmanageio(1);
AuxiliaryTask fdTask;
fdTask = Bela_createAuxiliaryTask(fdLoop, 50, "libpd-fdTask", NULL);
dcm.setVerbose(false);
gTrillTask = Bela_createAuxiliaryTask(readTouchSensors, 51, "touchSensorRead", NULL);
gTrillPipe.setup("trillPipe", 1024);
//MODIFIED
if(!mpr121.begin(1, 0x5A)) {
rt_printf("Error initialising MPR121\n");
return false;
i2cTask = Bela_createAuxiliaryTask(readMPR121, 50, "bela-mpr121");
readIntervalSamples = context->audioSampleRate / readInterval;
//return true;
// END MODIFIED
while(gGuiControlBuffers.size()) // this won't change within the loop, but it's good not to have to use a separate flag
static struct guiControlMessageHeader header;
static bool waitingForHeader = true;
if(waitingForHeader)
int ret = gGuiPipe.readRt(header);
if(1 != ret)
break;
else
waitingForHeader = false;
if(!waitingForHeader)
char payload[header.size + ('s' == header.type)]; // + 1 to add null termination if needed
int ret = gGuiPipe.readRt(&payload[0], header.size);
if(int(header.size) != ret)
break;
const char* name = gGuiControlBuffers[header.id].c_str();
if('f' == header.type)
if(header.size != sizeof(float))
rt_fprintf(stderr, "Unexpected message length for float: %u\n", header.size);
continue;
float value;
memcpy(&value, payload, sizeof(value));
libpd_add_float(value);
libpd_finish_message("bela_guiControl", name);
if('s' == header.type)
// add null termination
payload[header.size] = '\0';
// send to Pd
libpd_add_symbol(payload);
for(auto& b : gGuiDataBuffers)
int id = b.id;
int size = b.size;
const char* name = b.name.c_str();
if(id < 0)
// initialize
size = libpd_arraysize(name);
if(size <= 0)
continue;
} else {
// this is thread-unsafe: what happens if this causes reallocation while the Gui thread is writing to a buffer?
id = gui.setBuffer('f', size);
b.id = id;
b.size = size;
DataBuffer& dataBuffer = gui.getDataBuffer(id);
// initialize gui buffer with the initial content of the array
libpd_read_array(dataBuffer.getAsFloat(), b.name.c_str(), 0, size);
DataBuffer& dataBuffer = gui.getDataBuffer(b.id);
libpd_write_array(b.name.c_str(), 0, dataBuffer.getAsFloat(), dataBuffer.getNumElements());
while(gSerialInputTask) // proxy for 'isEnabled. Using `while` so we can do early return
enum WaitingFor_t {
kHeader,
kId,
kData,
static struct serialMessageHeader h;
static enum WaitingFor_t waitingFor = kHeader;
static char id[100];
if(kHeader == waitingFor)
int ret = gSerialPipe.readRt(h);
if(ret <= 0)
break;
waitingFor = kId;
if(kId == waitingFor)
if(h.idSize > sizeof(id) - 1)
rt_fprintf(stderr, "Serial: ID too large\n");
else
int ret = gSerialPipe.readRt(id, h.idSize);
if(ret <= 0)
break;
if(int(h.idSize) != ret)
rt_fprintf(stderr, "Invalid number of bytes read from gSerialPipe. Expected: %u, got %u\n", h.idSize, ret);
break;
id[ret] = '\0'; // ensure it's null-terminated
waitingFor = kData;
if(kData == waitingFor)
char data[h.dataSize + 1];
int ret = gSerialPipe.readRt(data, h.dataSize);
if(ret <= 0)
break;
if(int(h.dataSize) != ret)
rt_fprintf(stderr, "Invalid number of bytes read from gSerialPipe. Expected: %u, got %u\n", h.dataSize, ret);
break;
data[h.dataSize] = '\0'; // ensure it's null-terminated
if(h.dataSize)
const char* rec = "bela_serial";
if(kSerialSymbol == gSerialType)
libpd_symbol(rec, data);
} else {
unsigned int nTokens = 1;
const uint8_t separators[] = { ' ', '\0'};
// find number of delimiters
size_t start = 0;
for(size_t n = 0; n < sizeof(data); ++n)
for(size_t c = 0; c < sizeof(separators); ++c)
if(separators[c] == data[n] && n != start) // exclude empty tokens
start = n + 1;
nTokens++;
libpd_start_message(nTokens);
start = 0;
bool end = false;
if(separators[c] == data[n])
if(start == n)
start++; // remove empty tokens
else
end = true;
break; // no need to check for more separators
if(end)
data[n] = '\0'; // ensure the string is null-terminated so the next line works
if(kSerialSymbols == gSerialType)
libpd_add_symbol(data + start);
else if (kSerialFloats == gSerialType)
libpd_add_float(atof(data + start));
start = n + 1;
libpd_finish_message("bela_serial", id);
for(auto& name : gTrillAcks)
unsigned int idx = getIdxFromId(name.c_str(), gTouchSensors);
libpd_start_message(3);
libpd_add_symbol(Trill::getNameFromDevice(gTouchSensors[idx].second->deviceType()).c_str());
libpd_add_float(gTouchSensors[idx].second->getAddress());
libpd_add_symbol(Trill::getNameFromMode(gTouchSensors[idx].second->getMode()).c_str());
libpd_finish_message("bela_trillCreated", name.c_str());
gTrillAcks.resize(0);
bool doTrill = false;
for(auto& t : gTouchSensors)
if(Trill::NONE != t.second->deviceType())
doTrill = true;
break;
if(doTrill)
int idx;
while(gTrillPipe.readRt(idx) > 0)
Trill& touchSensor = *gTouchSensors[idx].second;
const char* sensorId = gTouchSensors[idx].first.c_str();
if(Trill::Device::NONE == touchSensor.deviceType())
continue;
const Trill::Mode mode = touchSensor.getMode();
if(Trill::DIFF == mode || Trill::RAW == mode || Trill::BASELINE == mode)
libpd_start_message(touchSensor.getNumChannels());
for(unsigned int n = 0; n < touchSensor.getNumChannels(); ++n)
libpd_add_float(touchSensor.rawData[n]);
} else if(Trill::CENTROID == mode)
if(touchSensor.is1D()) {
libpd_start_message(2 * touchSensor.getNumTouches() + 1);
libpd_add_float(touchSensor.getNumTouches());
for(unsigned int i = 0; i < touchSensor.getNumTouches(); i++) {
libpd_add_float(touchSensor.touchLocation(i));
libpd_add_float(touchSensor.touchSize(i));
} else if (touchSensor.is2D()) {
int numTouches = touchSensor.compoundTouchSize() > 0;
libpd_start_message(2 * numTouches + 1);
libpd_add_float(numTouches > 0);
if(numTouches)
libpd_add_float(touchSensor.compoundTouchHorizontalLocation());
libpd_add_float(touchSensor.compoundTouchLocation());
libpd_add_float(touchSensor.compoundTouchSize());
else
continue;
libpd_finish_message("bela_trill", sensorId);
static unsigned int count = 0;
unsigned int readIntervalSamples = touchSensorSleepInterval * context->audioSampleRate;
count += context->audioFrames;
if(count > readIntervalSamples)
Bela_scheduleAuxiliaryTask(gTrillTask);
count -= readIntervalSamples;
#ifdef PARSE_MIDI
int num;
switch(message.getType()){
case kmmNoteOn:
break;
case kmmNoteOff:
* with a velocity of 0.
break;
case kmmControlChange:
break;
case kmmProgramChange:
break;
break;
case kmmChannelPressure:
break;
case kmmPitchBend:
int value = ((message.getDataByte(1) << 7)| message.getDataByte(0)) - 8192;
break;
case kmmSystem:
int byte = channel | status;
break;
case kmmNone:
case kmmAny:
break;
#else
int input;
libpd_midibyte(port, input);
//audio input
for(unsigned int n = 0; n < context->audioInChannels; ++n)
memcpy(
gInBuf + n * gLibpdBlockSize,
// analog input
for(unsigned int n = 0; n < context->analogInChannels; ++n)
memcpy(
// multiplexed analog input
if(pdMultiplexerActive)
unsigned int j;
unsigned int k;
float* p0;
float* p1;
// digital input
if(gDigitalEnabled)
// digital in at message-rate
// digital in at signal-rate
// digital outputs
if(gDigitalEnabled)
// digital out at signal-rate
// scope output
gScopeOut[k] = *p1;
// audio output
for(unsigned int n = 0; n < context->audioOutChannels; ++n)
memcpy(
//analog output
for(unsigned int n = 0; n < context->analogOutChannels; ++n)
memcpy(
//MODIFIED
// Keep this code: it schedules the touch sensor readings
if(++readCount >= readIntervalSamples) {
readCount = 0;
Bela_scheduleAuxiliaryTask(i2cTask);
float sample = 0.0;
for(unsigned int ch = 0; ch < context->audioInChannels; ch++)
context->audioOut[context->audioInChannels * n + ch] = sample; */
//END MODIFIED
for(auto a : midi)
delete a;
for(auto t : gTouchSensors)
// t.first is a std::string, so the memory will be deallocated automatically
delete t.second;
libpd_closefile(gPatch);
delete [] gScopeOut;
//MODIFIED
// Auxiliary task to read the I2C board
for(int i = 0; i < NUM_TOUCH_PINS; i++) {
sensorValue[i] = -(mpr121.filteredData(i) - mpr121.baselineData(i));
sensorValue[i] -= threshold;
if(sensorValue[i] < 0)
sensorValue[i] = 0;
#ifdef DEBUG_MPR121
rt_printf("%d ", sensorValue[i]);
#endif
#ifdef DEBUG_MPR121
rt_printf("\n");
#endif
// You can use this to read binary on/off touch state more easily
//rt_printf("Touched: %x\n", mpr121.touched());
//SEND VALUES
libpd_float("electr0", sensorValue[0]);
libpd_float("electr1", sensorValue[1]);
libpd_float("electr2", sensorValue[2]);
libpd_float("electr3", sensorValue[3]);
//END MODIFIED
