Hi just trying to update my Bela and running into an error.
Image:
v0.3.7c, 27 February 2020
Core code:
Last attempted update on '2 Oct 2024 15:29:07 '
from file '/root/Bela/updates/Bela-master.zip'
via 'make update'
Update failed
Git desc: '2312ac65-dirty
Any ideas appreciated.
Many thanks
r/scripts/update_board ; exit;
DATE=2024-10-01T14:36:44Z
FILENAME=Bela-master
METHOD=update_board
Checking the board is up and running at root@192.168.7.2...Warning: Permanently added '192.168.7.2' (ED25519) to the list of known hosts.
done
Board found at root@192.168.7.2
Updating the Bela core code in root@192.168.7.2:/root/Bela
All the changes to the CORE files in the remote folder /root/Bela will be LOST. The content of these files/folders will be lost:
core include Makefile Makefile.libraries Makefile.linkbela examples Doxyfile scripts resources pru libraries
Your projects stored in /root/Bela/projects should be safe (and surely you have already backed them up somewhere safe, haven't you?).
Are you sure you want to continue? (y/N) y
Updating Bela core files to remote folder /root/Bela
Stopping Bela...done
Updating files...Updated files: 22 ...done
Scope
Using library Scope
Using library WSServer
Using library ne10
Midi
Using library Midi
Gui
Using library Gui
Trill
Using library Trill
Pipe
Using library Pipe
make: Entering directory '/root/Bela/resources/tools/bela-cape-btn'
gcc bela-cape-btn.c -o bela-cape-btn
bela-cape-btn.c: In function ‘run’:
bela-cape-btn.c:420:22: error: ‘pfd’ undeclared (first use in this function)
int result = poll(pfd, 1, pollTime);
bela-cape-btn.c:420:22: note: each undeclared identifier is reported only once for each function it appears in
Makefile:26: recipe for target 'bela-cape-btn' failed
make: *** [bela-cape-btn] Error 1
make: Leaving directory '/root/Bela/resources/tools/bela-cape-btn'
An error occurred.
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions... 9 completed.
Simon
