Hello Giulio,
I wonder if there is a Bela example to work with Sensor microphones, similar to what Arduino does. This is to sense the intensity of "clapping", or activated by "clapping". I have a KY-037 High Sensitive Sound Microphone Sensor. Thanks!
The KY-037 is a sensor module board with an electret microphone. You can set a threshold by turning the trimpot. When the signal level is louder than the threshold the digital pin goes high. The analog pin on the module delivers the current sound volume as a value continuously, independently from the threshold.
What part is in need for an example?
