I have a bela mini starter kit. I am using 8 boya m1 mics to record 8 channel sound without any problem, everything is fine, thanks for this product. Anyway, I want to use proffesional microphone for example 2012 Compact Cardioid Microphone. microphone uses XLR connection instead of jack, I may use xlr to jack connector to handle this situation. Can I use new microphone?
XLR connection with bela mini starter kit
The 2012 requires phantom power. You'll need a phantom power adapter and/or an external preamplifier. As the inputs are unbalanced, you'll need an adapter to connect only GND and the hot signal from the XLR connector to the audio input.
5 days later
so I can use it when I purchase this product which includes a phantom power and an xlr to jack converter right? https://www.yonkamuzikmarket.com/lastvoice-ph-1000s-48v-usb-phantom-power-ses-karti-xlr-kablo-7.1-kart-3.5-mm-jack-kablo-adaptor?gad_source=4
that looks reasonable
