• Trill
  • Bela Trill Craft - Failed to prepare Trill data collection
Hello,
I am migrating a project over from the Bela Mini to the Bela and I seem to be having issues with my Bela and am unsure where the issue is coming from.
I'm getting continuous "Failed to prepare Trill data collection / Failure to read Byte Stream" messages. Everything seems to be okay when I'm connected to the Mini so it doesn't seem to be an issue with the Trill Craft. I'm connected to P9.24 & P9.26, and can see a connection at 0x30 when I run i2cdetect.
I've updated the Bela software - unsure if there's anything else I should try?
Thank you!
Can you try the exact same sd card as the Mini on the Bela and see if that works?
    giuliomoro Oh yes it has! Does that mean its been flashed with the wrong image or something?? Thank you so much!
    You may have been using different versions of the library.
    What's the trill revision printed on the trill silkscreen? What's the version info you get in the Bela IDE-> settings -> other system settings-> bela version on each image?
