Hi everyone,
I am new to using Neural Network with Bela. I have downloaded a set of audio clips with sr = 16000Hz, and I am now pre-processing the data. I want to use tensorflow to perform NN, and convert to tflite then use on Bela for real time speech enhancement. I am aware that Bela only has two sr to choose from in the setting tab (screenshot below)
, what should I do in the pre-processing step? should I keep sr = 16000Hz and use librosa.resample(audio, orig_sr=16000, target_sr=44100) (or similar ) just before converting to tflite ? ( at this stage I will have done all the pre-processing and tranings); or can I keep sr = 16000Hz and it will still work fine on Bela ?
thank you very much!
