Hi all,
I have a Bela board attached to a Trill Craft, which has six lines of conductive thread sewn into a shirt, see below.
Each line is connected to a pad, and I'm trying to play different sounds depending on which line is touched.
I have print statements indicating which line is touched. However, I'm encountering an issue where only line 1 consistently plays a sound when touched. Some of the other lines do not register the touch at all, while others trigger sounds from line 1 or neighboring lines. I have wrapped inductive casing around each thread to try to prevent cross-capacitance, pictured below.
I suspect capacitance is jumping across the threads, though that doesn't explain why some lines aren't working. Each line is not touching another, and I have checked all the connections. Adjusting the prescalers and thresholds hasn't solved the problem; it causes some lines to trigger too close together and others not at all. I'd need a way to adjust each touch pad individually, as they are all behaving differently, but I haven't figured out if that's possible.
Has anyone faced similar issues, and how did you resolve them?
Thank you!
