• General
  • 70% CPU for "hello-sound" Pd patch?
Hi!
I'm running the "hello-sound" patch on the Bela+CTAG and it gives me 70% cpu usage + a red LED on the Bela board.
I removed all projects, updated the Bela software, and reset the default project settings but cpu remains unchanged (same for other tutorial Pd patavches). I assume this isn't normal. Any advice on how to investigate this issue?
Thanks!
That patch uses about 70% CPU on Bela, that's expected. On CTAG it will be slightly higher than that because the sampling rate is slightly higher (48k vs 44.1k) and there are more I/O channels.
Ah, that's simple:-) Thanks for the quick reply!!
