We are using only one PRU, and this can be either PRU0 or PRU1 (programmable in software). Only if you are using the Bela multiplexer capelet, you are required to run Bela on PRU1.
You can see the pins used by Bela here and you can check if they conflict with the ones used for the neopixel.
