Hi @max , thanks for your quick reply.
For this very first custom flex sensor project I am interested in making a larger flexible slider for implementation inside a wearable instrument. I basically just used the zigzag structure of the flex and tried to turn that into a larger design inside Kicad. Here is a zip file of the project on my server and here is the gerber file. Maybe you could give it a quick glance and give me some feedback?
Two questions that already come to mind: I noticed that OSHpark has as the maximum size for theri PCB's 16x22 inches. My design is a bit larger than that, about 642,1 x 50 mm (25x9 inch). Are there manufacturers out there that you would recommend that produce larger flexible sensor designs on order?
Furthermore: on the PCB design it is mentioned in a user comment just above the connector, where it says 'STIFFENER BOTTOM', it says 'Make sure to export layer "User.1" to Gerber and rename to "Stiffener"'.
Does this mean that the renaming should take place after exporting to Gerber inside the Gerber directory? In my case I find a file in there (along with 12 others) that is called 'es-flexible-sensor-User_1.gbr'. Should this one be renamed to 'es-flexible-sensor-Stiffener.gbr'?
Thanks in advance!
Sjoerd
