It's a very simple patch, I just wanted to test the voltage output of the digital pins. Here's the patch:
#N canvas 334 303 450 300 10;
#X obj 71 50 loadbang;
#X msg 98 102 out 11;
#X obj 98 124 s bela_setDigital @hv_param;
#X obj 71 72 t b b;
#X obj 71 180 del 1000;
#X msg 71 202 1;
#X obj 71 224 s bela_digitalOut11 @hv_param;
#X connect 0 0 3 0;
#X connect 1 0 2 0;
#X connect 3 0 4 0;
#X connect 3 1 1 0;
#X connect 4 0 5 0;
#X connect 5 0 6 0;
I created this project through the IDE by choosing PureData and uploading a _main.pd file (I included the @hv_param just to get the hang of it, since I want to build my final patch with Heavy, since it will likely consume some CPU).
The thing is that even the Pure Data examples provided with the IDE won't run.
Is there some script that can remedy this situation? Maybe the update_board script would do?
