Hi I am trying to use a stereo splitter to get two mono signal inputs from a 6.35mm TRS input into Bela.
Although this fritzing diagram does not show the splitter, the wiring is the same. I'm connecting one leg of each 1M resistor to each signal leg of the TRS and then connecting the other legs from the resistors to 3.3V. The piezos are then connected via 6.35mm mono jacks:
However, whenever I want to trigger a signal with a single piezo (adc1), it also triggers the other signal from adc2. I don't think my Pd patch is what's causing the problem:
I think it's the wiring. I've seen other posts where multiple piezos are used, but these are connected each to an analog input rather than using the audio inputs, so I'm not really sure what went wrong here.
