nickcamillo When I try a new IC, it flashes 2 or 3 times and then it stops
If you power it off and then on again, does it work again? It's unlikely you'd be frying it with the current-limited 3.3V outputs from Bela. What part are you using exactly? Did you double check the pinout and wiring against its datasheet? It sounds like you may have it wired wrong.
