this runs:
s = Server.default;
s.options.numAnalogInChannels = 8;
s.options.numAnalogOutChannels = 8;
s.options.blockSize = 2048;
s.options.postln;
s.waitForBoot({
var freq01,freq02,freq03,dur01,dur02,dur03,amp01,amp02,amp03,pan01,pan02,pan03,legato; // define variables
SynthDef(\rand01,
{ |out = 0, freq = 440, dur = 0.2, amp = 0.2, pan = 0| // adding values here (arguement list) are defaults if they are not overwritten by pbind later.
var env, sig, filt;
env = EnvGen.kr(Env.perc(0.45, 4), doneAction: 2); //envelope
sig = LFSaw.ar(freq, 0, amp * env); // sawtooth
filt = LPF.ar(sig, 1200); // low pass filter, down to 1200Hz
pan = Pan2.ar(filt, pan);
Out.ar(out, pan);
).add;
SynthDef(\rand02,
var env, sig, filt, verb;
env = EnvGen.kr(Env.perc(0.01, 6), doneAction: 2); // envelope
sig = SinOsc.ar(freq, 0, amp * env); // sine
filt = Pan2.ar(sig * 0.2, pan); //scaling
verb = FreeVerb.ar(filt, mix: 0.92, room: 0.91, damp: 0.2); // adding verb
Out.ar(out, sig + verb);
).add;
SynthDef(\rand03,
var env, sig, verb, filt;
env = EnvGen.kr(Env.perc(0.8, 6), doneAction: 2);
sig = LFTri.ar(freq, 0, amp * env);
filt = LPF.ar(sig, 3000);
pan = Pan2.ar(filt * 0.2, pan); //scaling
verb = FreeVerb.ar(pan, mix: 0.7, room: 0.91, damp: 0.01);
).add;
// s.sync;
freq01 = Pwhite(40,60,80, 100, inf); // pwhite-random values between low and high range. here its between 40 and 100 Hz for infinity.
freq02 = Pdup(Prand([100, 200, 500], inf), Pwhite(-1.0, 1.0));
freq03 = Pwhite(800, 3000, inf);
dur01 = Pdup(Prand([0.5, 1, 2, 3], inf), Pwhite(1, 5)); //prand random values from array. pdup duplicates array values x times stated in pwhite.
dur02 = Pwhite(0.1, 1.2, inf);
dur03 = Pwhite(0.1, 1.4, inf);
amp01 = Pwhite(0.1, 0.2, inf);
amp02 = Pwhite(0.1, 0.3, inf);
amp03 = Pwhite(0.1, 0.2, inf);
pan01 = Pwhite(-1, 1, inf);
pan02 = Pwhite(-1, 1, inf);
pan03 = Pwhite(-1, 1, inf);
legato = Pwhite(0, 1, inf); // legato between 0 and 100% overlap from last note
Pbind( // // pbind puts together synthdef and patterns-i think it plays patterns with synthdefs?.
\instrument, \rand01, //playing synthdef rand01
\freq, freq01, //read from above
\dur, dur01,
\amp, amp01,
\pan, pan01
).play;
Pbind(
\instrument, \rand02,
\freq, freq02,
\dur, dur02,
\amp, amp02,
\pan, pan02,
\legato, legato,
).play;
Pbind(
\instrument, \rand03,
\freq, freq03,
\dur, dur03,
\amp, amp03,
\pan, pan03,
\legato, legato,
).play;
ServerQuit.add({ 0.exit }); // quit if the button is pressed
I only really made sure that it was wrapped in s.waitForBoot as a single block (i.e.: moved the variable declaration to the top, removed the () blocks) and used the template Bela Sc code (the one you get when creating a new Sc project on Bela) for what's outside s.waitForBoot(). Even with the larger-than-usual block size I used, you'll still get dropouts, as the peak CPU usage is higher than what the board can provide. I suspect the issue is with the maximum polyphony / duration of the notes.
