weightausend Hi, I’m developing a project which requires the configuration of 2 analog joysticks to control parameters in Pure Data. Has anyone already used some? Would these work with bela? http://www.handsontec.com/dataspecs/accessory/PS2-Joystick.pdf I don’t understand if the 5V voltage would be too much for the analog in. Also, could I connect the 5V out directly from the Bela GPIO? Or would it be better to create a separate power supply? Thanks for your help.
giuliomoro From what I see in the datasheet, it's just two pots and one button, no active electronics. So if you use 3.3V from Bela it should work just fine, sending out 1.65V at rest, 0V on one side and 3.3V on the other side.
weightausend Sorry for the long delay, but I've tested it with 3 joysticks and all works very well! cheers
