hi
didn't really find a similar issue here, but correct me if i'm wrong.
i'm trying to use the [loop_] function, and made three test projects called loop_A, loop_B and loop_C, respectively. very lightweight Pd patches.
set to run on boot, loop_A starts up just fine. pressing the button causes expected behaviour (in a way), in that it shuts down the running program and tries to move to loop_B.
i then get the following:
Apr 19 14:38:35 bela stdbuf[95]: make: Leaving directory '/root/Bela'
Apr 19 14:38:35 bela stdbuf[95]: Running /root/Bela/projects/loop_B
Apr 19 14:38:35 bela stdbuf[95]: make: Entering directory '/root/Bela'
Apr 19 14:38:36 bela stdbuf[95]: Running /root/Bela/projects/loop_B/loop_B
Apr 19 14:38:36 bela stdbuf[95]: /bin/sh: 1: /root/Bela/projects/loop_B/loop_B: not found
Apr 19 14:38:36 bela stdbuf[95]: Makefile:612: recipe for target 'runonly' failed
Apr 19 14:38:36 bela stdbuf[95]: make: *** [runonly] Error 127
Apr 19 14:38:36 bela stdbuf[95]: make: Leaving directory '/root/Bela'
Apr 19 14:38:36 bela stdbuf[95]: Running /root/Bela/projects/loop_C
Apr 19 14:38:36 bela stdbuf[95]: make: Entering directory '/root/Bela'
Apr 19 14:38:36 bela stdbuf[95]: Running /root/Bela/projects/loop_C/loop_C
Apr 19 14:38:36 bela stdbuf[95]: /bin/sh: 1: /root/Bela/projects/loop_C/loop_C: not found
Apr 19 14:38:36 bela stdbuf[95]: Running /root/Bela/projects/loop_A
Apr 19 14:38:37 bela stdbuf[95]: Running /root/Bela/projects/loop_A/loop_A
so it fails to find the project files, it would seem?
i tried re-copying the _main.pd patches into the projects after setting loop_* to start at boot, without succes.
i tried turning the start at boot on and off (loop > none > loop) as advised elsewhere.
for context, i am (still) trying to add an OLED to pepper.
ideally, i'd run O2O in the background as a service file, and use the [loop_] function to switch between project files.
the problem i'm encountering seems to be unrelated to the background service, as it persists whether that is enabled or not.
thoughts?
