Dear all,
I'm working on a wearable enclosure for the Bela right now - and I would like to break out a power on/off switch and some indicator LEDs to be mounted on the outside of the box. The goal is that the whole system can be easily (and safely) powered on and off without ever having to open it up.
So.. question.. does anyone in the community have any experience boxing up the Bela for an installation or instrument? If so, what did you break out on the enclosure itself? My system is powered via an external battery - is it wise to simply splice a power switch into the battery cable - turning the system on/off via cutting the power?
There are quite a few status LEDs flashing on the BBB, are these accessible via the IO pins? If so, which would be the most valuable ones?
thanks & happy 2018!
Jon
EDIT: there's some discussion about pros and cons of hard vs soft shutdowns of the Bela
here https://forum.bela.io/d/462-shutdown-button-not-working
and here https://forum.bela.io/d/261-suggestions-on-adding-a-power-on-off-switch
and here https://forum.bela.io/d/68-turning-off-the-bbb
aaaand here.. https://forum.bela.io/d/261-suggestions-on-adding-a-power-on-off-switch
stupid that I didn't look deeply enough for this on my own.. :-)
