wang2930 My Bela Mini used to work perfectly fine. However, recently, when I plugged it in, only a solid blue light appeared. I attempted to reflash the SD card following the official tutorial, but unfortunately, it didn't resolve the issue. Any suggestions?
giuliomoro Do you have anything connected to it, and/or did it shut down abruptly the last time you used it?
wang2930 giuliomoro I haven't used it for about a year now. I'm pretty sure I didn't shut it down abruptly last time. And all the setup should still be the same.
wang2930 giuliomoro A Bela Mini multichannel expander is connected to it. But I've tested it without the expander. The issue was still there. Apart from that, there's only an SD card inserted and a wire linking the Bela Mini to my computer.
