Tristan Can you confirm these are the appropriate settings please? I want to run with audio out amplified by 5 volts and have analog inputs.
giuliomoro those look good. Is it not working for you? Two common reasons why that may not work: step 23 of the build guide: make sure you insert the IC into the cradle and that the orientation is correct step 24 of the build guide: make sure you solder the 4x1 socket on the Bela cape
