Hello,
I am having trouble with a new Bela module. It seems that bool setup is running normally and returns true; however, void render does not seem to be running. I thought maybe this was some problem in my code, so I ran the print example. I get the following output in Bela's command window when running the print example project:
Building project...make:
Nothing to be done for `all'.
Build finishedRunning project...
This Bela example has just started running!
Here's the value of pi: 3.141593
Then nothing else prints to the console even though there should be a new message every second (according to code in void render function).
Anyone have an idea as to what might be going on? Why won't the render function run?
Thanks,
Dan
