Hello, i am using bela just to read microphone outputs and send the live datas to the computer in real time. When i record the microphones and listen to the wav files. All microphones are working clearly but, when i try to decimate then transmit the microphone outputs. I am receiving nonsense values like e^-33,-38 some very high values like e37 and after the code sends 3-4 frames it gives segmentation error.
I share the code snippets below:
std::vector<std::vector<float>> gInputs;
std::vector<std::vector<float>> gOutputs;
std::vector<std::vector<float>> gOut_temp;
std::vector<float> gFile; // 2 dimensional vector for audio samples, consists channels and their frames
std::string gFilenameInputs = "dene_5.wav";
// UDP Communication
UdpClient* audio_client;
int remotePort =40001; // remote IP port
const char* remoteIP = "192.168.7.1"; // remote IP, where data will be published
unsigned int gWrittenFrames = 0; // how many frames written to gOutBuf
unsigned int byte_0 = 0;
unsigned int byte_size = 0;
unsigned int frame_counter = 0;
const int frame_stop = 96;
std::vector<std::vector<float>> gFileBuf(1, std::vector<float>(frame_stop*8*256, 0));
std::vector<Biquad> gBiquads; // filters to process the inputs
gFileBuf.resize(1);
gInputs.resize(8);
gOutputs.resize(1);
gOut_temp.resize(8);
try {
for(auto& k : gInputs)
k.resize(1024);
for(auto& k : gOut_temp)
k.resize(1024);
for(auto& t : gOutputs)
t.resize(2*1024);
for(auto& c : gFileBuf)
c.resize(frame_stop*8*256);
catch (std::exception& e) { // error case; inform the user
fprintf(stderr, "Error while allocating memory. Maybe you are asking to record too many frames and/or too many channels\n");
return false;
Biquad::Settings settings {
.fs = 48000,
.type = Biquad::lowpass,
.cutoff = 10000,
.q = 0.707,
.peakGainDb = 0,
gBiquads.resize(std::min(context->audioInChannels, context->audioOutChannels), Biquad(settings));
audio_client = new UdpClient(remotePort,remoteIP); // UDP client is initialized
byte_size = context->audioFrames;
// second_time = time(NULL);
// printf("%i", second_time - first_time, "\n");
// loops to store audio inputs
for(unsigned int n = 0; n < context->audioFrames; ++n) // loop to read all frames, processing frame by frame to ensure syncronisation
unsigned int c;
// process audio inputs through the filter, write to the audio outputs and store the audio outputs
for(c = 0; c < gBiquads.size(); ++c) {
float in = audioRead(context, n, c);
float out = gBiquads[c].process(in);
gOut_temp[c][gWrittenFrames] = out;
if (n%4 ==0){
gOutputs[0][c*256+n] = out;
++gWrittenFrames;
for (unsigned int i = 0; i<512;++i)
gOutputs[0][i] = 0.3;
printf("%f %f %f \n",gOutputs[0][128],gOutputs[0][440],gOutputs[0][1670]);
byte_0= audio_client->send(&gOutputs[0], 8192);
I am trying to solve this problem for almost 4 days now. I added the decimation operation after i tried the send the data as it is and still without the decimation i cannot send the datas without a problem.
https://forum.bela.io/d/3913-problem-with-sending-multichannel-audio-signal-through-udp/2
I think i missed something small yet important because this task should not be that hard 🙂
Any help is appreciated.
Thank you
