Hi Giulio, @giuliomoro, I am writing to ask about an issue about digital pin state. I hooked up a simple digital in/out circuit for the example in the library. Basically it triggers a tone once the button is pressed and the led blinks. It was all fine and worked as expected. But, when I was setting up another wiring, I heard a buzz and the connection broke. When I plug Bela back and test the example project, I found that the digital pin states are reversed( the tone and the led is by default on and once push the button the tone and the led disappears). Also, the Bela mini becomes very noise after that sudden disconnection. I'm thinking it might be an issue of a short circuit when I was wiring. Do you what the issue might be? (I was trying to upload a video but I couldn't).
