I started working with the IDE a bit, and I was wondering about how do you save your changes.
If I open some of the examples, then if I press Ctrl-S in the IDE, I'm asked to save my edit as a new project. I guess, that means that the examples are read-only - so far so good.
Then I start editing my copy project; then when I press Ctrl-S here, the code is apparently saved - but also Bela starts building immediately, and most of the time I don't want that, so I have to press stop once it starts building.
Is there a shortcut in the IDE that does only save without build - or if not, coud I configure Ctrl-S to do save only (without building)?
