Hi,
I'm unable to access the Else library even though I have it installed as PD external. What can be the possible issue?
It was installed on the Bela operating system.
It doesn't come installed as default. Did yoy install it yourself?
Right, do you have any instructions from them on how they installed it or how to use it?
/root/Bela/pd-externals/else This kind of method. I did already also [declare -path /root/Bela/projects/pd-externals/else] in the patch but did not work. I'd like to understand the essence of the problem.
Well, to begin with, the error you show is that the object is not recognised when running Pd on your computer, not on Bela.
So that mean that I need .pd version of that external instead of only .linux probably right?
On desktop pd you can install externals via the menu -> find externals tool (aka deken)
10 months later
Hi!
Does else compilation exist anywhere for Bela? It seems that deken package are only for amd64.
...but enough for my needs, thank you!!!
