If you are still getting the same error, it may be that you did not update the code on the board?
Can you do ssh root@192.168.7.2 grep HEAVY_ARCHIVE Bela/Makefile
? It should return this:
# if heavy-unzip-archive, then we should have a HEAVY_ARCHIVE=...
ifeq (,$(HEAVY_ARCHIVE))
$(error Missing HEAVY_ARCHIVE=... for target heavy-unzip-archive)
$(AT) [ -z "$(HEAVY_ARCHIVE)" ] && { echo "You should specify the path to the Heavy archive with HEAVY_ARCHIVE=" >&2; false; } || true
$(AT) [ -f "$(HEAVY_ARCHIVE)" ] || { echo "File $(HEAVY_ARCHIVE) not found" >&2; false; }
$(AT) unzip -qq -d $(HEAVY_TMP_DIR) $(HEAVY_ARCHIVE) && rm -rf $(HEAVY_ARCHIVE)
if it returns fewer lines than this, then you have not updated the Bela core code on the board, or something went wrong in the process, or it's yet another bug!
What is failing is the new feature that retrieves pre-compiled files from the Heavy server, making compilation much faster. If the error persists, try to add: --src-only
to the build_pd_project.sh
command line. This will compile the files locally and will be a bit slower (the same as it used to be), but it should work.
As for the errors you get at compilation time: the Heavy API has changed since then. Heavy releases are officially supported for 6 months, and your code may still be using the old one from august 2016. One temporary solution is to keep using it (it seems that it is still available online). Do this by adding -r r2016.08 --src-only
command line. (the --src-only
here is needed because the server-side compilation was added only for more recent releases).
Even if the above works, you are encouraged to bring your render file up to date. Here's how:
1) with the new Heavy API, if you want to send messages from Heavy ( the Pd patch) out to the C++ wrapper, you need to add @hv_param
to your [send]
object, e.g.: [send myreceiver @hv_param]
2) here is a diff of the changes I made to the default heavy render.cpp
to make it suitable for the newer API:
diff --git a/scripts/hvresources/render.cpp b/scripts/hvresources/render.cpp
index b6c1a93..0062c34 100644
--- a/scripts/hvresources/render.cpp
+++ b/scripts/hvresources/render.cpp
@@ -27,7 +37,7 @@ unsigned int hvMidiHashes[7];
unsigned int gScopeChannelsInUse;
float* gScopeOut;
// Bela Scope
-static Scope scope;
+static Scope* scope = NULL;
@@ -36,10 +46,10 @@ static bool pdMultiplexerActive = false;
* HEAVY CONTEXT & BUFFERS
-Hv_bela *gHeavyContext;
+HeavyContextInterface *gHeavyContext;
float *gHvInputBuffers = NULL, *gHvOutputBuffers = NULL;
unsigned int gHvInputChannels = 0, gHvOutputChannels = 0;
-struct HvTable* multiplexerTable = NULL;
+uint32_t multiplexerTableHash;
float gInverseSampleRate;
@@ -50,8 +60,9 @@ float gInverseSampleRate;
// TODO: rename this
#define LIBPD_DIGITAL_OFFSET 11 // digitals are preceded by 2 audio and 8 analogs (even if using a different number of analogs)
-void printHook(double timestampSecs, const char *printLabel, const char *msgString, void *userData) {
- rt_printf("Message from Heavy patch: [@ %.3f] %s: %s\n", timestampSecs, printLabel, msgString);
+void printHook(HeavyContextInterface *context, const char *printLabel, const char *msgString, const HvMessage *msg) {
+ const double timestampSecs = ((double) hv_msg_getTimestamp(msg)) / hv_getSampleRate(context);
+ rt_printf("Message from Heavy patch: [@ %.3f] %s: %s\n", timestampSecs, printLabel, msgString);
@@ -71,28 +82,28 @@ char hvDigitalInHashes[16][21]={
{"bela_digitalIn26"}
+// For a message to be received here, you need to use the following syntax in Pd:
+// [send receiverName @hv_param]
static void sendHook(
- double timestamp, // in milliseconds
- const char *receiverName,
- const HvMessage *const m,
- void *userData) {
+ HeavyContextInterface *context,
+ const char *receiverName,
+ hv_uint32_t sendHash,
+ const HvMessage *m) {
- // Bela digital
// Bela digital run-time messages
// TODO: this first block is almost an exact copy of libpd's code, should we add this to the class?
// the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between 11 and 26
- static int prefixLength = 15; // strlen("bela_digitalOut")
+ static const int prefixLength = 15; // strlen("bela_digitalOut")
if(strncmp(receiverName, "bela_digitalOut", prefixLength)==0){
if(receiverName[prefixLength] != 0){ //the two ifs are used instead of if(strlen(source) >= prefixLength+2)
if(receiverName[prefixLength + 1] != 0){
- int receiver = ((receiverName[prefixLength] - 48) * 10);
- receiver += (receiverName[prefixLength+1] - 48);
+ int receiver = ((receiverName[prefixLength] - '0') * 10);
+ receiver += (receiverName[prefixLength+1] - '0');
unsigned int channel = receiver - LIBPD_DIGITAL_OFFSET; // go back to the actual Bela digital channel number
- bool value = hv_msg_getFloat(m, 0);
+ bool value = (hv_msg_getFloat(m, 0) != 0.0f);
if(channel < 16){ //16 is the hardcoded value for the number of digital channels
dcm.setValue(channel, value);
@@ -102,133 +113,103 @@ static void sendHook(
// Bela digital initialization messages
- if(strcmp(receiverName, "bela_setDigital") == 0){
- // Third argument (optional) can be ~ or sig for signal-rate, message-rate otherwise.
- // [in 14 ~(
- // [s bela_setDigital]
- // is signal("sig" or "~") or message("message", default) rate
- bool isMessageRate = true; // defaults to message rate
- bool direction = 0; // initialize it just to avoid the compiler's warning
- bool disable = false;
- int numArgs = hv_msg_getNumElements(m);
- if(numArgs < 2 || numArgs > 3 || !hv_msg_isSymbol(m, 0) || !hv_msg_isFloat(m, 1))
- return;
- if(numArgs == 3 && !hv_msg_isSymbol(m,2))
- return;
- char * symbol = hv_msg_getSymbol(m, 0);
- if(strcmp(symbol, "in") == 0){
- direction = INPUT;
- } else if(strcmp(symbol, "out") == 0){
- direction = OUTPUT;
- } else if(strcmp(symbol, "disable") == 0){
- disable = true;
- } else {
- return;
- int channel = hv_msg_getFloat(m, 1) - LIBPD_DIGITAL_OFFSET;
- if(disable == true){
- dcm.unmanage(channel);
- return;
- if(numArgs >= 3){
- char* s = hv_msg_getSymbol(m, 2);
- if(strcmp(s, "~") == 0 || strncmp(s, "sig", 3) == 0){
- isMessageRate = false;
+ switch (sendHash) {
+ case 0x70418732: { // bela_setDigital
+ // Third argument (optional) can be ~ or sig for signal-rate, message-rate otherwise.
+ // [in 14 ~(
+ // [s bela_setDigital]
+ // is signal("sig" or "~") or message("message", default) rate
+ bool isMessageRate = true; // defaults to message rate
+ bool direction = 0; // initialize it just to avoid the compiler's warning
+ bool disable = false;
+ if (!(hv_msg_isSymbol(m, 0) && hv_msg_isFloat(m, 1))) return;
+ const char *symbol = hv_msg_getSymbol(m, 0);
+ if(strcmp(symbol, "in") == 0){
+ direction = INPUT;
+ } else if(strcmp(symbol, "out") == 0){
+ direction = OUTPUT;
+ } else if(strcmp(symbol, "disable") == 0){
+ disable = true;
+ } else {
+ return;
+ int channel = hv_msg_getFloat(m, 1) - LIBPD_DIGITAL_OFFSET;
+ if(disable == true){
+ dcm.unmanage(channel);
+ return;
+ if(hv_msg_isSymbol(m, 2)){
+ const char *s = hv_msg_getSymbol(m, 2);
+ if(strcmp(s, "~") == 0 || strncmp(s, "sig", 3) == 0){
+ isMessageRate = false;
+ dcm.manage(channel, direction, isMessageRate);
+ break;
- dcm.manage(channel, direction, isMessageRate);
- return;
- if(strcmp(receiverName, "bela_noteout") == 0){
- if(numArgs != 3){
- return;
+ case 0xEC6DA2AF: { // bela_noteout
+ if (!hv_msg_hasFormat(m, "fff")) return;
+ midi_byte_t pitch = (midi_byte_t) hv_msg_getFloat(m, 0);
+ midi_byte_t velocity = (midi_byte_t) hv_msg_getFloat(m, 1);
+ midi_byte_t channel = (midi_byte_t) hv_msg_getFloat(m, 2);
+ rt_printf("noteon: %d %d %d\n", channel, pitch, velocity);
+ midi.writeNoteOn(channel, pitch, velocity);
+ break;
- midi_byte_t pitch = hv_msg_getFloat(m, 0);
- midi_byte_t velocity = hv_msg_getFloat(m, 1);
- midi_byte_t channel = hv_msg_getFloat(m, 2);
- rt_printf("noteon: %d %d %d\n", channel, pitch, velocity);
- midi.writeNoteOn(channel, pitch, velocity);
- return;
- if(strcmp(receiverName, "bela_ctlout") == 0){
- if(numArgs != 3){
- return;
+ case 0xD44F9083: { // bela_ctlout
+ midi_byte_t value = (midi_byte_t) hv_msg_getFloat(m, 0);
+ midi_byte_t controller = (midi_byte_t) hv_msg_getFloat(m, 1);
+ rt_printf("controlchange: %d %d %d\n", channel, controller, value);
+ midi.writeControlChange(channel, controller, value);
+ break;
- midi_byte_t value = hv_msg_getFloat(m, 0);
- midi_byte_t controller = hv_msg_getFloat(m, 1);
- rt_printf("controlchange: %d %d %d\n", channel, controller, value);
- midi.writeControlChange(channel, controller, value);
- return;
- if(strcmp(receiverName, "bela_pgmout") == 0){
- if(numArgs != 2){
- return;
+ case 0x6A647C44: { // bela_pgmout
+ if (!hv_msg_hasFormat(m, "ff")) return;
+ midi_byte_t program = (midi_byte_t) hv_msg_getFloat(m, 0);
+ midi_byte_t channel = (midi_byte_t) hv_msg_getFloat(m, 1);
+ rt_printf("programchange: %d %d\n", channel, program);
+ midi.writeProgramChange(channel, program);
+ break;
- midi_byte_t program = hv_msg_getFloat(m, 0);
- midi_byte_t channel = hv_msg_getFloat(m, 1);
- rt_printf("programchange: %d %d\n", channel, program);
- midi.writeProgramChange(channel, program);
- return;
- if(strcmp(receiverName, "bela_bendout") == 0){
- if(numArgs != 2){
- return;
+ case 0x545CDF50: { // bela_bendout
+ unsigned int value = ((midi_byte_t) hv_msg_getFloat(m, 0)) + 8192;
+ rt_printf("pitchbend: %d %d\n", channel, value);
+ midi.writePitchBend(channel, value);
+ break;
- unsigned int value = hv_msg_getFloat(m, 0) + 8192;
- rt_printf("pitchbend: %d %d\n", channel, value);
- midi.writePitchBend(channel, value);
- return;
- if(strcmp(receiverName, "bela_touchout") == 0){
- if(numArgs != 2){
- return;
+ case 0xDE18F543: { // bela_touchout
+ midi_byte_t pressure = (midi_byte_t) hv_msg_getFloat(m, 0);
+ rt_printf("channelPressure: %d %d\n", channel, pressure);
+ midi.writeChannelPressure(channel, pressure);
+ break;
- midi_byte_t pressure = hv_msg_getFloat(m, 0);
- rt_printf("channelPressure: %d %d\n", channel, pressure);
- midi.writeChannelPressure(channel, pressure);
- return;
- if(strcmp(receiverName, "bela_polytouchout") == 0){
- if(numArgs != 3){
- return;
+ case 0xAE8E3B2D: { // bela_polytouchout
+ midi_byte_t pressure = (midi_byte_t) hv_msg_getFloat(m, 1);
+ rt_printf("polytouch: %d %d %d\n", channel, pitch, pressure);
+ midi.writePolyphonicKeyPressure(channel, pitch, pressure);
+ break;
- midi_byte_t pressure = hv_msg_getFloat(m, 1);
- rt_printf("polytouch: %d %d %d\n", channel, pitch, pressure);
- midi.writePolyphonicKeyPressure(channel, pitch, pressure);
- return;
- if(strcmp(receiverName, "bela_midiout") == 0){
- if(numArgs != 2){
- return;
+ case 0x51CD8FE2: { // bela_midiout
+ midi_byte_t byte = (midi_byte_t) hv_msg_getFloat(m, 0);
+ int port = (int) hv_msg_getFloat(m, 1);
+ rt_printf("port: %d, byte: %d\n", port, byte);
+ midi.writeOutput(byte);
+ break;
- midi_byte_t byte = hv_msg_getFloat(m, 0);
- int port = hv_msg_getFloat(m, 1);
- rt_printf("port: %d, byte: %d\n", port, byte);
- midi.writeOutput(byte);
- return;
+ default: break;
@@ -252,7 +233,7 @@ bool setup(BelaContext *context, void *userData) {
if(context->audioInChannels != context->audioOutChannels ||
context->analogInChannels != context->analogOutChannels){
// It should actually work, but let's test it before releasing it!
- printf("Error: TODO: a different number of channels for inputs and outputs is not yet supported\n");
+ fprintf(stderr, "Error: TODO: a different number of channels for inputs and outputs is not yet supported\n");
return false;
/* HEAVY */
@@ -272,7 +253,7 @@ bool setup(BelaContext *context, void *userData) {
hvMidiHashes[kmmChannelPressure] = hv_stringToHash("__hv_touchin");
hvMidiHashes[kmmPitchBend] = hv_stringToHash("__hv_bendin");
- gHeavyContext = hv_bela_new(context->audioSampleRate);
+ gHeavyContext = hv_bela_new_with_options(context->audioSampleRate, 10, 2, 0);
gHvInputChannels = hv_getNumInputChannels(gHeavyContext);
gHvOutputChannels = hv_getNumOutputChannels(gHeavyContext);
@@ -285,7 +266,7 @@ bool setup(BelaContext *context, void *userData) {
gHvOutputChannels - gFirstDigitalChannel - gScopeChannelsInUse: 0;
printf("Starting Heavy context with %d input channels and %d output channels\n",
- gHvInputChannels, gHvOutputChannels);
+ gHvInputChannels, gHvOutputChannels);
printf("Channels in use:\n");
printf("Digital in : %u, Digital out: %u\n", gDigitalSigInChannelsInUse, gDigitalSigOutChannelsInUse);
printf("Scope out: %u\n", gScopeChannelsInUse);
@@ -309,8 +290,12 @@ bool setup(BelaContext *context, void *userData) {
midi.enableParser(true);
if(gScopeChannelsInUse > 0){
- // block below copy/pasted from libpd, except
- scope.setup(gScopeChannelsInUse, context->audioSampleRate);
+#if __clang_major__ == 3 && __clang_minor__ == 8
+ fprintf(stderr, "Scope currently not supported when compiling heavy with clang3.8, see #265 https://github.com/BelaPlatform/Bela/issues/265. You should specify `COMPILER gcc;` in your Makefile options\n");
+ exit(1);
+#endif
+ scope = new Scope();
+ scope->setup(gScopeChannelsInUse, context->audioSampleRate);
// Bela digital
@@ -321,11 +306,13 @@ bool setup(BelaContext *context, void *userData) {
// unlike libpd, no need here to bind the bela_digitalOut.. receivers
- multiplexerTable = hv_getTableForName(gHeavyContext, multiplexerArray);
- if(context->multiplexerChannels > 0 && multiplexerTable != NULL){
+ // but make sure you do something like [send receiverName @hv_param]
+ // when you want to send a message from Heavy to the wrapper.
+ multiplexerTableHash = hv_stringToHash(multiplexerArray);
+ if(context->multiplexerChannels > 0){
pdMultiplexerActive = true;
- hv_table_resize(multiplexerTable, multiplexerArraySize);
+ hv_table_setLength(gHeavyContext, multiplexerTableHash, multiplexerArraySize);
hv_sendFloatToReceiver(gHeavyContext, hv_stringToHash("bela_multiplexerChannels"), context->multiplexerChannels);
@@ -347,7 +334,7 @@ void render(BelaContext *context, void *userData)
// rt_printf("message: noteNumber: %f, velocity: %f, channel: %f\n", noteNumber, velocity, channel);
- hv_vscheduleMessageForReceiver(gHeavyContext, hvMidiHashes[kmmNoteOn], 0, "fff",
+ hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmNoteOn], 0, "fff",
(float)noteNumber, (float)velocity, (float)channel+1);
break;
@@ -360,7 +347,7 @@ void render(BelaContext *context, void *userData)
// note we are sending the below to hvHashes[kmmNoteOn] !!
(float)noteNumber, (float)0, (float)channel+1);
break;
@@ -368,14 +355,14 @@ void render(BelaContext *context, void *userData)
- hv_vscheduleMessageForReceiver(gHeavyContext, hvMidiHashes[kmmControlChange], 0, "fff",
+ hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmControlChange], 0, "fff",
(float)value, (float)controller, (float)channel+1);
break;
case kmmProgramChange: {
- hv_vscheduleMessageForReceiver(gHeavyContext, hvMidiHashes[kmmProgramChange], 0, "ff",
+ hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmProgramChange], 0, "ff",
(float)program, (float)channel+1);
break;
@@ -384,7 +371,7 @@ void render(BelaContext *context, void *userData)
- hv_vscheduleMessageForReceiver(gHeavyContext, hvMidiHashes[kmmPolyphonicKeyPressure], 0, "fff",
+ hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmPolyphonicKeyPressure], 0, "fff",
(float)channel+1, (float)pitch, (float)value);
break;
@@ -392,7 +379,7 @@ void render(BelaContext *context, void *userData)
- hv_vscheduleMessageForReceiver(gHeavyContext, hvMidiHashes[kmmChannelPressure], 0, "ff",
+ hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmChannelPressure], 0, "ff",
(float)value, (float)channel+1);
break;
@@ -400,7 +387,7 @@ void render(BelaContext *context, void *userData)
int value = ((message.getDataByte(1) << 7) | message.getDataByte(0));
- hv_vscheduleMessageForReceiver(gHeavyContext, hvMidiHashes[kmmPitchBend], 0, "ff",
+ hv_sendMessageToReceiverV(gHeavyContext, hvMidiHashes[kmmPitchBend], 0, "ff",
break;
@@ -438,7 +425,7 @@ void render(BelaContext *context, void *userData)
- memcpy(hv_table_getBuffer(multiplexerTable), (float *const)context->multiplexerAnalogIn, multiplexerArraySize * sizeof(float));
+ memcpy(hv_table_getBuffer(gHeavyContext, multiplexerTableHash), (float *const)context->multiplexerAnalogIn, multiplexerArraySize * sizeof(float));
@@ -471,9 +458,17 @@ void render(BelaContext *context, void *userData)
// replacement for bang~ object
- //hv_vscheduleMessageForReceiver(gHeavyContext, "bela_bang", 0.0f, "b");
+ //hv_sendMessageToReceiverV(gHeavyContext, "bela_bang", 0.0f, "b");
- hv_bela_process_inline(gHeavyContext, gHvInputBuffers, gHvOutputBuffers, context->audioFrames);
+ hv_processInline(gHeavyContext, gHvInputBuffers, gHvOutputBuffers, context->audioFrames);
+ for(int n = 0; n < context->audioFrames*gHvOutputChannels; ++n)
+ printf("%.3f, ", gHvOutputBuffers[n]);
+ if(n % context->audioFrames == context->audioFrames - 1)
+ printf("\n");
// Bela digital out
// Bela digital out at signal-rate
@@ -512,7 +507,7 @@ void render(BelaContext *context, void *userData)
gScopeOut[k] = *p1;
- scope.log(gScopeOut);
+ scope->log(gScopeOut);
@@ -541,11 +536,9 @@ void render(BelaContext *context, void *userData)
- hv_bela_free(gHeavyContext);
- if(gHvInputBuffers != NULL)
- free(gHvInputBuffers);
- if(gHvOutputBuffers != NULL)
- free(gHvOutputBuffers);
+ hv_delete(gHeavyContext);
+ free(gHvInputBuffers);
+ free(gHvOutputBuffers);
delete[] gScopeOut;
+ delete scope;
