Hi there,
I was hoping to experiment with this I2c device and naively thought I would be able to hack the trill examples. But I have realised I probably need to port the adafruit Arduino library over to Bela... And I don't really know what I am doing.
https://learn.adafruit.com/adafruit-tsc2007-i2c-resistive-touch-screen-controller/arduino
I am planning to get the data into supercollider.
I would probably tackle it alone on an Arduino but on Bela I usually use the lovely web interface and I don't even know where the libraries live, how to create one etc.
I am sure it's trivial for others here so if anyone can point me in the right direction that would be great. I would also be open to paying for someone for help port a library over / or do an online tutorial as this is the sort of thing that will likely confuse me for days.
Many thanks
Simon
So I watched this from its 4 years ago but it suggests that you can't make your own Bela libraries. Is that still the case
Sorry for the questions.. I am just new to this and used to Teensy, and Arduino where the library code is easy to grab and mess with.
Many thanks
Simon
Well, you can. These "libraries" on Bela are reusable classes that you can use in your C++ projects. We don't have a great workflow, but you can indeed write them and add them in. If out of this project came a usable library for this resistive display, I would be very happy to help you integrating it.
Writing Supercollider ugens is kind of complicated and neither Trill nor your display would strictly need one, because you don't need to process audio in these ugens. A better approach that is easier to code and can be used from any programming language can be to have a device-OSC bridge that can run as a stand-alone program on the side of your audio processing program and that you can send or receive OSC from. There are a number of examples doing just this:
OSC to OLED https://github.com/giuliomoro/O2O
OSC to Neopixels https://github.com/giuliomoro/O2L
OSC to/from Trill https://github.com/BelaPlatform/Trill-Linux/tree/master/examples/trill-osc
Once you have such a program, you can run it as a service as explained here https://learn.bela.io/using-bela/bela-techniques/running-a-program-as-a-service/ .
Now, for your specific application, we could have a multi-step approach:
  1. write a standalone program that doesn't do any audio processing but manages to connect to the screen, reads from it and prints to console
  2. have it send OSC
  3. run it as a service
Now for step 1, I was coincidentally planning on doing some work on adding a compatibility layer for Wire and/or the Adafruit I2C library, so I could do it that way (slower) or just make it work (faster). It's going to be fun either way because I don't have the device.
Hi giuliomoro,
Thanks so much for that detailed reply. Makes total sense. I am happy to send you a display and the adafruit driver display. Honestly I would rather mess around with the supercollider sound making bit. You could mail me on simon@simonblackmore.net and we could take that further. I am also looking at another adafruit driver that outputs serial and that is probably easier for me to implement if I were to go it alone. But they seem to be stopping producing that one.
https://www.adafruit.com/product/1580
Many thanks
Simon
    simonb I am happy to send you a display and the adafruit driver display.
    Thanks, hopefully that won't be necessary.
    This should build as a project on your Bela board (you can download this as a zip archive, drop it on the IDE and use the ensuing dialog to create a project off of it). It expects you to connect the device to the I2C1 bus (the pins highlights as I2C in the pin diagram for your board).
    Give it a try and let me know if it displays any results with your sensor.
    Ah ok cool... That sounds doable. I just can't get my head around the IDE at the moments. So if I make a new project I get render .cpp file and a Bela.h file which I can't access.
    Don't I need to be able to access the header file and include libraries like...
    #include <linux/i2c.h>
    Do you mean I just grab something like the "printing to the console" example and add to it until I get data from the I2C bus.. not worry about the header file.
    like this.....
    #include <cmath>
    float gInterval = 0.5;
    float gSecondsElapsed = 0;
    int gCount = 0;
     // Write a command byte to the TSC2007 and read the 2-byte response
    // look at how you are handling this stuff in the trill library
        // Print a string
    	rt_printf("This Bela example has just started running!\n");
    	// after loads of coffee and hacking about
        rt_printf("the data from the screen magically appears and then I work on sending it as osc");
    Thanks again for the help.
      simonb Do you mean I just grab something like the "printing to the console" example and add to it until I get data from the I2C bus.. not worry about the header file.
      No, I mean literally just putting that code in a project exactly the way it is. Download it as a zip archive from github, drag the archive on top of the IDE, follow the instructions in the dialog to create the project from it and execute it as it is. As it contains a main() function, it will execute that and not any of the "Bela" stuff that normally happens in the background.
      Ok I think I get what you mean...
      I read through this...
      https://learn.bela.io/using-bela/bela-techniques/using-an-oled-screen/
      Downloaded the zip.... (which my Mac seems to automatically unzip so I have to zip it again.)
      I drop that into Bela and get access to all the files. and it looks like this. And I can build it from there.
      Is that right? What's the best project to clone as a starting point?
      Cheers
      Simon
      Oh wow magic!.... Did you you just knock that up? amazing. Right that looks like a good start.
      Thanks!
      So, dropped it in and it runs which I am seeing as a small victory.
      Unfortunately saying...
      "Bela: Couldn't find touch controller"
      sensor lights are on and 99.9% all connections are good so just checking through.
      Thanks again
      Can you show your wiring? Also, that assumes that the device is using its default address of 0x48. Also, with the sensor connected run in the console at the bottom of the IDE:
      i2cdetect -y -r 1
      and show the result here
      Cool thanks so much. OK two pics. I think it's using the default address.
      ok I amended the repo, get the updated version and try again.
      That works.... Amazing thanks so much. So now I just need to figure out how to send it out via OSC to SC. What's the best approach there?
      OK I updated the repo so that it sends to localhost:1234 an OSC message to address /tsc containing four integers with the values you were previously seeing printed. For prototyping purposes , you may want it to send to the host computer instead, in which case replace "hostAddress = localhost" with "hostAddres = 192.168.7.1" (or 192.168.6.1, depending on what address your computer has on the point-to-point network with Bela), also adjust the port number to taste.
      I can receive this with this simple Pd patch, surely it's easy enough to do in Supercollider as well:
      If this works as expected, then use the instructions here https://learn.bela.io/using-bela/bela-techniques/running-a-program-as-a-service/ to run it in the background while you run a proper Bela program on the side.
      That's great...thanks.
      Something going wrong on my end though.
      Wow you are amazing... looks like it's working. The running as a service looks well documented so will try that later.
      Do you have one of those buy me a coffee type things?
      Thanks!!
