vicky I have used the Pd 'playback sample' sketch (managed to download and ref the ~map object) . I swapped out the 'greek.wav' for my own .wavpath on computer. Got the following error msg...
You need to upload the file to the board (drop it in the IDE) and then just use
[read -resize ANCOATS.wav table-1]
(note the space between "resize" and the filen ame).
vicky How do I go about playback... it seems to not ref the table 1 ...
there is a [tabread~ table-1] at the very bottom of the patch in your screenshot.
vicky I can't seem to find how to assign trill hub pins and then daisy chain off this for the individual sensors?
If the trill sensors you are using are all of the same type, they will default all to the same address. In order to be able to use more than one on the HUB, you will need a soldering iron to set the address pins, see here https://learn.bela.io/using-trill/using-multiple-sensors/#changing-addresses
