That is a opaque pointer used to pass arguments around. That pointer is passed to the Bela backend when calling the int Bela_initAudio(BelaInitSettings *settings, void *userData) function. Any Bela project that does not have a custom main.cpp file uses under the hood core/default_main.cpp, which contains the call to Bela_init(), and passes a NULL pointer as userData. This means that if you do not have a custom main.cpp, then userData is not used.
Some of the example projects provide a custom main() function and use userData to pass some data retrieved from the command-ilne to the setup() function:
./04-Audio/FFT-phase-vocoder/render.cpp: gSampleData = *(SampleData *)userData;
./10-Instruments/d-box/render.cpp: int oscBankHopSize = *(int *)userData;
./11-Extras/second-pru/render.cpp: int pruNumber; // comes from userData
./11-Extras/second-pru/render.cpp: // Which PRU to use is in userData, assuming this project
./11-Extras/second-pru/render.cpp: if(userData == 0) {
./11-Extras/second-pru/render.cpp: pruNumber = *((int *)userData);
./11-Extras/second-pru/render.cpp: int pruNumber = *((int *)userData);
./11-Extras/userdata/render.cpp: if(userData != 0)
./11-Extras/userdata/render.cpp: gFrequency = *(float *)userData;
./terminal-only/filter-FIR/render.cpp: gSampleData = *(SampleData *)userData;
./terminal-only/filter-IIR/render.cpp: gSampleData = *(SampleData *)userData;
./terminal-only/samples/render.cpp: gSampleData = *(SampleData *)userData;
However, similar results could be achieved - in the context of a Bela project - using global variables.
The most powerful use of userData, however, is when embedding Bela into an other application. For instance, in the code for the Bela backend for SuperCollider, userData is a pointer to a driver object instance:
Bela_initAudio(&settings, this)
at that point, every time the audio callback function (sc_belaRender()) is called, it is passed a reference to the driver object and it can (after appropriate casting) access its members:
void sc_belaRender(BelaContext *belaContext, void *userData)
SC_BelaDriver *driver = (SC_BelaDriver*)userData;
driver->BelaAudioCallback(belaContext);
