dws Hello, I accidentally burned my bbb last week. Luckily, I have a bbai at home. Is there a Bela-OS capable of running on the bbai; I know it won't be stable, it's just to see if I also burned the BelaCape. So sad dawams
giuliomoro see if you can work your way through the instructions here: https://dhruvag2000.github.io/Blog-GSoC21/ Btw, how did you burn the BBB? Maybe knowing that is enough to assess whether the cape is likely OK.
dws I did a performance in a place where the electricity was unstable: the surrounding lights flashed regularly. I powered the beagle from the 5v power supply of a pc. This power supply also powered, in 12v, a wiper motor.
giuliomoro If an over voltage came in via the barrel jack, the power amplifier on the Bela cape is probably gone, but I the rest may be OK.
