I am very new to this, I have a few years of laser cutting experience so I have the rough draft idea of the design I want and a semblance of an idea on how the instrument should work, I still need to learn how to code tho. Planning on using an arduino nano with 1 craft but am open to multiple. Basically want a keytar with keys on the neck and a 4 wire touch screen as an xyz on the base(like a misa/mosi). I would like pitch bending per note and vibrato/portamento if I could combine those in one (think of an artiphon instrument 1 for example). I dont think I could combine those as I have read in a separate thread there is only variance with how much the skin contacts the area so with that, I am thinking 0.75 inch keys for a total of 25 keys in a thin line that ends in a stacked pile for each key (think of the emoji but upside down ig lol) and a switch to do those different modes for that extra variance such as aftertouch, vibrato, pitch bend, portamento, etc. It would be with copper foil as a prototype before Id get a pcb made. I would like the xyz controller to be able to do multiple modes with a switch as well to do stuff like strum, tap mode, a regular mode with velocity tied to z, mod would still be y and have an extra x for whatever else but would be happy with it just being a mod and extra effect if I cant achieve that, any advice or tips for a beginner would be greatly appreciated!
craft tips for a beginner?
Sounds interesting. Where do you want to do the sound processing? Is the instrument just sending prameters via MIDI/OSC or is the sound generation happening on it too?
max just midi for now, maybe I could implement a daisy seed later on down the line . I have since came to the conclusion of adding 2 more crafts as I have thought to do a separate layer of copper tape per row of triangles,(think of an hourglass) below the top layer of keys, this would be pitch up and down, however it would be separated by a small silicone layer that would need pressed down to gain capacitance. I am not sure if this would short the circuit or effectively turn it into an fsr tho so definitely need to research more. Any tips or ideas would be greatly appreciated, my goal is to have a working proto around March but not completely sure of route yet haha!
