x_x are these then C28, C29 ?
On Rev B1, yes
x_x the worst thing what could happen is clipping as there are voltage clamps 0 - 3.3v ?
The Rev B1 cape as the one you have doesn't have clamping diodes, but only ESD protectors, so it's particularly fragile with the DC-coupled mod if used stand-alone. On the other hand, the 84k series resistor from Pepper should provide more than enough current protection.
Note that the combined input circuit is:
input jack 84K 15K
AUDIO_IN_R-------R16----+-----R18-----GND
| AUDIO_IN_R_SCALED
PEPPER |
BELA CAPE |
C29 |
LINE1RP codec input
So once you bypass C29 you are connecting AUDIO_IN_R_SCALED directly to the codec's input LINE1RP. The common-mode voltage at LINE1RP is fixed at somewhere between 1.2V and 1.8V .. I never measured it and I can't find it on the datasheet, so it's up to you to figure it out ... measure it when the cape is not connected to Pepper.
Keep in mind that R16, R18 and the input impedance of the codec (which is between 20k and 80k depending on the PGA and any attenuation/boost , see section 10.3.8 "Input Impedance and VCM Control" and Table 8.5 "Electrical characteristics" of the datasheet) will interact together and that whatever the common mode voltage is, that will be the value that corresponds to an audio input of 0 in the digital domain, so you may need to add an extra DC shift (e.g.: with a large resistor (> 10k) from Pepper's +10V VOLTAGE_SELECT_OUTPUT) in order for a 0V input to result in approx 0 in the digital domain.
