My Bela no longer maps as USB drive, neither as network device.
It gets power over usb, but nothing then.
It works via Ethernet.
Tested under Windows and OSX, several cables and Updated via IDE.
I've also run without SD card without luck.
Any ideas? Is my BBB broken?
adding output of dmesg | grep error (just in case)
dmesg | grep error
[ 0.509464] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.511114] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 1.288333] omap_uart 48022000.serial: did not get pins for uart1 error: -19
[ 8.901514] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
