Hi,
I am trying to create and save a wav file using this code on Bela. However, I am not sure where the wav file is saved too on my laptop or on Bela.
Does anyone know where this might be??
Appreciate any help
#include <libraries/Biquad/Biquad.h>
#include <vector>
#include <string>
#include <algorithm>
std::vector<std::vector<float>> gInputs;
std::vector<std::vector<float>> gOutputs;
std::string gFilenameOutputs = "outputs.wav";
std::string gFilenameInputs = "inputs.wav";
const double gDurationSec = 20; // how many seconds to record.
unsigned int gWrittenFrames = 0; // how many frame have actually been written to gInputs and gOutputs
std::vector<Biquad> gBiquads; // filters to process the inputs
// pre-allocate all the memory needed to store the audio data
unsigned int numFrames = context->audioSampleRate * gDurationSec;
gInputs.resize(context->audioInChannels);
gOutputs.resize(context->audioOutChannels);
// If we have too many channels or too many frames to store, we may run out of RAM and
// the program will fail to start.
try {
for(auto& c : gInputs)
c.resize(numFrames);
for(auto& c : gOutputs)
} catch (std::exception& e) {
fprintf(stderr, "Error while allocating memory. Maybe you are asking to record too many frames and/or too many channels\n");
return false;
Biquad::Settings settings {
.fs = context->audioSampleRate,
.type = Biquad::lowpass,
.cutoff = 200,
.q = 0.707,
.peakGainDb = 0,
// create some filters to process the input
gBiquads.resize(std::min(context->audioInChannels, context->audioOutChannels), Biquad(settings));
// store audio inputs
for(unsigned int c = 0; c < context->audioInChannels; ++c)
gInputs[c][gWrittenFrames] = audioRead(context, n, c);
unsigned int c;
// process audio inputs through the filter, write to the audio outputs and store the audio outputs
for(c = 0; c < gBiquads.size(); ++c) {
float in = audioRead(context, n, c);
float out = gBiquads[c].process(in);
gOutputs[c][gWrittenFrames] = out;
++gWrittenFrames;
if(gWrittenFrames >= gOutputs[0].size()) {
// if we have processed enough samples an we have filled the pre-allocated buffer,
// stop the program
Bela_requestStop();
return;
// ensure we don't write any more frames than those that have actually been processed
// this way if the program is stopped by the user before its natural end we don't end up
// with a lot of empty samples at the end of each file.
for(auto& i : gInputs)
i.resize(gWrittenFrames);
for(auto& o : gOutputs)
o.resize(gWrittenFrames);
AudioFileUtilities::write(gFilenameInputs, gInputs, context->audioSampleRate);
AudioFileUtilities::write(gFilenameOutputs, gOutputs, context->audioSampleRate);
