I have been loading wav files into Bela using the scp command as follows:
scp -r SoundBanks/ root@bela.local:Bela/projects/myProject
On my laptop (MacBook Pro) this always works just fine. However, my colleague just tried the same approach on a Windows machine, and several of the wav files would not play, because they were apparently corrupted. I downloaded the files back from Bela onto the computer and they are indeed corrupted, giving an error code 0xC00D36C4.
We tried the same thing with the Windows machine several times, and in every instance some files were corrupted - though not always the same wav files every time.
Is there a better way to do this, or at least to check for corruption of files and try again?
Thanks!
