Thanks for answering!
I just bought an extra sd and flashed newest Bela image to it. I some how thought that there were two versions of SC on Bela. But if it's the same one and included already on the latest image then I'm actually good already!
But just for clarifying the error that I got:
I typed '$ dpkg - l | grep libudev'
And got answer: 'dpkg: error: need an action option'.. and bunch of help options.
Also when executing the cmake command I get some error while building the cmake files. In the middle there is mentioned:
hidapi cmakelists
===linux hidraw cmakelists===
-- UDev not found.
-- UDev: You can specify includes: -DUDEV_PATH_INCLUDES=/opt/udev/include
-- currently found includes: UDEV_INCLUDE_DIR-NOTFOUND
-- UDev: You can specify libs: -DUDEV_PATH_LIB=/opt/udev/lib
-- currently found libs: UDEV_LIBRARIES-NOTFOUND
CMake Warning (dev) at external_libraries/hidapi/CMakeLists.txt:59 (link_directories):
This command specifies the relative path
