I am trying to follow your instructions of the preview posts (exemplified below):
"So, you could try to remove that IP address (revert the dropdown to "DHCP"). "
In Portuguese it says that the ethernet adaptor has the same ip address and cant connect to the internet
"This way, both computers at the two ends of the ethernet cable (Bela and your laptop) will self-assign an IP address. I am not sure how this works, because I don't understand it entirely, but it's possible it will work. In this configuration, if you can access http://bela.local in the browser, you should be able to connect to the board."
At this point, I cant still run bela.local
" Then you need to figure out the IP address of the computer: go back to network preferences, it will say the computer has a self assigned IP address. Copy that address and put it in your Sc patch. See if it works."
I don't have access to bela.local still, but I will try when it is ready!
