Hi there,
I'm trying to move a project I built with and Arduino and PD onto a Bela mini.
All worked well when I was working with the Arduino. When I moved to the Bela mini I'm getting huge fluctuation on the sensor values coming from the force sensitive resistors. I could run the bela and the values could be 0.3 and then the next time 5 mins later 0.8. This makes it difficult to set the threshold value. Nothing has changed in the wiring.
I've added a pot to set the threshold manually each time I run the bela, but this will not be possible for the final application.
I'm powering the bela mini via USB from my Macbook air. I intend to switch to an external power supply after I finish prototyping.
Has anyone had any experience with this issue?
