I have made a simple program that outputs 8 LFOs, 4.096Vpp + 2.048V (DC), to keep it within the Bela's usable input's range. However, when these are plugged back into the inputs, the waveform is cut at about half the amplitude.
Furthermore, without anything connected to them, the maximum DC voltage at my inputs is about 9V, give or take.
I am attaching my scope, which shows
Blue: the LFO, directly sent from my code (scaled by 1/4.096 to keep max at 1):
Red: LFO back into input
Green: 2nd analog input, which with pots turn to maximum shows 0.9006V
#include <cmath>
#include <iostream>
Scope scope;
int gAudioFramesPerAnalogFrame = 0;
float gInverseSampleRate;
float gPhase1, gPhase2, gPhase3, gPhase4, gPhase5, gPhase6, gPhase7, gPhase8;
float gAmplitude = 2.048;
float gFrequency = 0.1;
float DCamplitude = 2.048;
float gIn1, gIn2, gIn3, gIn4, gIn5, gIn6, gIn7, gIn8;
float LFO1, LFO2, LFO3, LFO4, LFO5, LFO6, LFO7, LFO8;
// For this example you need to set the Analog Sample Rate to
// 44.1 KHz which you can do in the settings tab.
// setup the scope with 3 channels at the audio sample rate
scope.setup(16, context->audioSampleRate);
if(context->analogSampleRate > context->audioSampleRate)
fprintf(stderr, "Error: for this project the sampling rate of the analog inputs has to be <= the audio sample rate\n");
return false;
if(context->analogInChannels < 2)
fprintf(stderr, "Error: for this project you need at least two analog inputs\n");
return false;
if(context->analogFrames)
for(unsigned int n = 0; n < context->audioFrames; n++)
// generate a sine wave with the amplitude and frequency
LFO1 = gAmplitude * sinf(gPhase1) + DCamplitude;
gPhase1 += 2.0f * (float)M_PI * gFrequency * gInverseSampleRate;
if(gPhase1 > M_PI)
gPhase1 -= 2.0f * (float)M_PI;
LFO2 = gAmplitude * sinf(gPhase2) + DCamplitude;
gPhase2 += 2.0f * (float)M_PI * gFrequency * 2 * gInverseSampleRate;
if(gPhase2 > M_PI)
gPhase2 -= 2.0f * (float)M_PI;
LFO3 = gAmplitude * sinf(gPhase3) + DCamplitude;
gPhase3 += 2.0f * (float)M_PI * gFrequency * 4 * gInverseSampleRate;
if(gPhase3 > M_PI)
gPhase3 -= 2.0f * (float)M_PI;
LFO4 = gAmplitude * sinf(gPhase4) + DCamplitude;
gPhase4 += 2.0f * (float)M_PI * gFrequency * 8 * gInverseSampleRate;
if(gPhase4 > M_PI)
gPhase4 -= 2.0f * (float)M_PI;
LFO5 = gAmplitude * sinf(gPhase5) + DCamplitude;
gPhase5 += 2.0f * (float)M_PI * gFrequency * 16 * gInverseSampleRate;
if(gPhase5 > M_PI)
gPhase5 -= 2.0f * (float)M_PI;
LFO6 = gAmplitude * sinf(gPhase6) + DCamplitude;
gPhase6 += 2.0f * (float)M_PI * gFrequency * 32 *gInverseSampleRate;
if(gPhase6 > M_PI)
gPhase6 -= 2.0f * (float)M_PI;
LFO7 = gAmplitude * sinf(gPhase7) + DCamplitude;
gPhase7 += 2.0f * (float)M_PI * gFrequency * 64 * gInverseSampleRate;
if(gPhase7 > M_PI)
gPhase7 -= 2.0f * (float)M_PI + DCamplitude;
LFO8 = gAmplitude * sinf(gPhase8) + DCamplitude;
gPhase8 += 2.0f * (float)M_PI * gFrequency * 128 * gInverseSampleRate;
if(gPhase8 > M_PI)
gPhase8 -= 2.0f * (float)M_PI;
gIn1 = analogRead(context, n/gAudioFramesPerAnalogFrame, 0);
gIn2 = analogRead(context, n/gAudioFramesPerAnalogFrame, 1);
gIn3 = analogRead(context, n/gAudioFramesPerAnalogFrame, 2);
gIn4 = analogRead(context, n/gAudioFramesPerAnalogFrame, 3);
gIn5 = analogRead(context, n/gAudioFramesPerAnalogFrame, 4);
gIn6 = analogRead(context, n/gAudioFramesPerAnalogFrame, 5);
gIn7 = analogRead(context, n/gAudioFramesPerAnalogFrame, 6);
gIn8 = analogRead(context, n/gAudioFramesPerAnalogFrame, 7);
analogWriteOnce(context, n/2, 0, LFO1);
analogWriteOnce(context, n/gAudioFramesPerAnalogFrame, 1, LFO1);
analogWriteOnce(context, n/gAudioFramesPerAnalogFrame, 2, LFO3);
analogWriteOnce(context, n/gAudioFramesPerAnalogFrame, 3, LFO4);
analogWriteOnce(context, n/gAudioFramesPerAnalogFrame, 4, LFO5);
analogWriteOnce(context, n/gAudioFramesPerAnalogFrame, 5, LFO6);
analogWriteOnce(context, n/gAudioFramesPerAnalogFrame, 6, LFO7);
analogWriteOnce(context, n/gAudioFramesPerAnalogFrame, 7, LFO8);
// log the sine wave and sensor values on the scope
scope.log(gIn1, LFO8, gIn2);
