jayrope Warning:
-A/--adc-level is deprecated and IGNORED. Use --audio-input-gain instead
Warning: --pga-gain-left is deprecated. Use --audio-input-gain instead
Warning: --pga-gain-right is deprecated. Use --audio-input-gain instead
Running Pd 0.51-4
Not much to worry about. If you don't like it, run rm /root/Bela/projects/PROJECTNAME/settings.json and refresh the page. If you had any project-specific settings you had set, you'll have to re-set them after this.
jayrope But it doesn't say or seem to be the newest:
Version details
Image:
v0.3.4, 31 May 2018
Core code:
Last updated on '2 Feb 2023 10:23:46 '
via 'make update (legacy)'
Update was successful
Git desc: '1c973ef-dirty'
That looks good to me. Just a warning, the 2 here is wrong, it just means you updated on a Tuesday (damn Javascript getDay() vs getDate() (I am fixing it now). Anyhow, this means you updated your core code last in february 2023.
If you are confused by this:
Image:
v0.3.4, 31 May 2018
that's because this will only change when flashing a new image, .
