Hi all,
I'm still working on a bridge program that I'm trying to line out in pseudocode in the following:
In C++
1. Collecting data from 2 BNO085 (waiting for data to arrive over I2C, writing them to the respective local variables, sensors are NOT synchronized)
2. Sending aggregated data over OSC for sonification with SuperCollider ON the Bela exactly every 10ms
In SuperCollider:
3. Sonification based on sensor data
I'm having problems reaching AND holding the 10ms. Even when I create a separate thread it fluctuates between 10 and 30ms.
I realized that it might make sense to create a xenomai thread instead of a normal thread.
But I cannot wrap my head around.
Does that even make sense? If so, how would I create a xenomai thread?
I can provide parts of the code, it's just really messy atm.
Thanks a best,
Thomas
I'd recommend you have everything on a single thread, e.g. (copying some stuff I don't understand from https://github.com/giuliomoro/belaonurhead/blob/master/lib/libpd-render-with-IMU.cpp, and also assuming that you are using the other files from that folder):
#include <Bela_BNO055.h>
#include <oscpkt.hh>
std::vector<I2C_BNO055> bnos(2);
UdpClient udpClient;
// Quaternions and Vectors
imu::Quaternion gCal, gCalLeft, gCalRight, gIdleConj = {1, 0, 0, 0};
imu::Quaternion qGravIdle, qGravCal, quat, steering, qRaw;
imu::Vector<3> gRaw;
imu::Vector<3> gGravIdle, gGravCal;
imu::Vector<3> ypr; //yaw pitch and roll angles
int calibrationState = 0; // state machine variable for calibration
int setForward = 0; // flag for setting forward orientation
int main()
	udpClient.setup(1234, "192.168.7.1"); // use 192.168.7.1 to send to host or 192.168.7.2 to send to other program on Bela
	// TODO: bno initialisation here
	while(1)
		oscpkt::Message msg("/address/path");
		for(auto& bno : bnos)
			// just copying code I don't really understand from readIMU() in
			// https://github.com/giuliomoro/belaonurhead/blob/master/lib/libpd-render-with-IMU.cpp
			// (includes undeclared variables)
			// get calibration status
			uint8_t sys, gyro, accel, mag;
			bno.getCalibration(&sys, &gyro, &accel, &mag);
			// quaternion data routine from MrHeadTracker
			imu::Quaternion qRaw = bno.getQuat(); //get sensor raw quaternion data
			if( setForward ) {
				gIdleConj = qRaw.conjugate(); // sets what is looking forward
				setForward = 0; // reset flag so only happens once
			steering = gIdleConj * qRaw; // calculate relative rotation data
			quat = gCalLeft * steering; // transform it to calibrated coordinate system
			quat = quat * gCalRight;
			ypr = quat.toEuler(); // transform from quaternion to Euler
			msg.pushFloat(ypr[0]).pushFloat(ypr[1]).pushFloat(ypr[2]);
		oscpkt::PacketWriter pw;
		pw.init().addMessage(msg);
		udpClient.send(	pw.packetData(), pw.packetSize());
		// the instructions above will take some time (especially reading I2C),
		// so to achieve 10ms period you will have to tweak the below
		usleep(90000);
	return 0;
Try out the above. If the timing is not accurate enough for you, then you should turn this into a RT thread (i.e.: Linux thread with SCHED_FIFO and priority > 0). A Xenomai thread won't give any meaningful advantage over a SCHED_FIFO thread, because you are using I2C and networking which have to go through Linux.
