yehezkelraz Hi! I have a problem with RNBO and Bela I've uploaded the rnbo.example.bela-main file into the IDE and I got lots of error messages. The project won't run. I also tried to replace the rnbo_project.ccp file with a simple c++ export from RNBO - just a sine wave connected to an output - and same error message.. Max version is 8.5.2
giuliomoro can you show the tab of the IDE with the project settings? what do you see in "User command line" ? If it's empty, then you should update your core code for this to work. Follow instructions here
yehezkelraz Thank you. yes, it's empty. I updated Bela's core code with the link you sent and it's still empty:
giuliomoro but does the project work after the update? If it doesn't, please show the beginning of the printout, as in your previous screenshot it is truncated.
yehezkelraz it does now🙂 amazing thank you! **I've updated it again, not with the IDE update (it didn't seem to work) but with the update_board script..
