Hello all!
Just finished building my Pepper and am already working on some things. Looking forward to sharing projects with everyone.
I was actually curious if anyone has ever built a breakout board of sorts for easier access to the digital/analog in selections that are typically made with the jumpers?
It seems like it should be relatively simple, but being that I am pretty new to diy electronics, I'm thinking there is probably something I am missing. Is it possible to wire the jumper pins/circuits of a channel to one single switch?
Thanks!
    jonbenderr . Is it possible to wire the jumper pins/circuits of a channel to one single switch?
    no, you would need a multi-pole switch which are bulky and expensive. Perhaps the best option is to add a 2U panel on the side with 4 more jacks which you can wire up to the "unused setting" (i.e.: digital or analog) on the main board.
    nice final results, lots of wires there though ... why did you need so many?
    Because of the pepper design to switch from Analog to digital. You have 6-pin jumpers for each channel, where 5 need to be connected. (BTW: if you had swapped pin 1 and 2 for J17 on the PCB, it would only be necessary to use 1 5pin jack instead of 2 jacks (4-pin and 2-pin, because 1 wire is redundant).
    I agree, I could have spared 6 wires and connect all the other switches to the first one, but this would have resulted in more effort (6 more solder points). And I think my wiring is cleaner (regarding maintenance).
